1990 5.0 LX Notch
PCV Valve???
Lastnight at the track I kept blowing it out of the block. Any way to keep this from happening?
Newblet
1987 GT
If you have some electrical/duct tape I would try that
1990 5.0 LX Notch
Well that grommet was coming out with it.
Newblet
1987 GT
Well there is a lip on that gommet and I would try wrapping some tape around it. The grommet on mine is loose but I dont race it so it usually stays put. I am going to try the duct tape on mine soon though.
I just bought a new grommet, PCV valve and the hose that goes to the intake manifold and it is still loose |
1997 Mustang GT
13.56@102.94
If it's blowing it out, you either need a new grommet and/or pcv and grommet.
When you shake it does the check valve inside move freely?
![]() 1997 Mustang GT Aluminum Block PI swap & 4R70W to TR3550 swapped. Best 1/8: 2.04 60ft 8.74@81.85 & Best 1/4: 2.045 60ft 13.56@102.94 all on stock 245-17's My Garage |
Take the grommet out and clean any oil from the intake hole and the grommet. Put a thin layer of black RTV on the outside of the grommet and put it back in the manifold and let it cure. That's worked for me in the past. I've put a few turns of electrical tape around the PCV and shoved it in and that worked but one time the tape came loose and started to suck up into the PCV. I won't do that again.
1988 GT
+1, and maybe you need more ventilation. Are you running that line from your oil fill tube to your TB?
1990 5.0 LX Notch
1984 Mustang LX
0-Never
seriously its a $2 part if its giving you trouble try replacving it.
1984 Ford Mustang LX ![]() The Wheels are HAWT I know. |
1990 5.0 LX Notch
i know you dont want to hear it, but its also possible that you may have some water mixed in with your oil. that makes steam. steam make ALOT of pressure. Probably not whats actually going on, but its still a possibility
Threads Similar to: PCV Valve???
| PCV Valve | whtpny | 99-04 | 2 | October 5th, 2008 08:03 PM |
| pcv valve | gooberhead320 | General Tech | 2 | August 27th, 2008 02:57 AM |
| Egr Valve And Pcv Valve Delete? | Jeffery9508 | V6 Mustangs | 16 | January 28th, 2008 09:45 PM |
| pcv valve? | El_Cangri | V6 Mustangs | 12 | June 1st, 2007 10:07 PM |
| Where Is It? (PCV Valve) | cobraetti | General Tech | 3 | August 6th, 2006 09:16 PM |
