cam install
Old March 5th, 2009, 12:56 AM   #1
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
cam install
Originally Posted by Iwannagofast View Post
thats a completely different thread....not an easy question to answer that quickly
this is for you iwanna
whats the easiest way to do it and what all would i need as far as parts and special tools to do it besides the obvious cam and basic tool set?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old March 5th, 2009, 01:51 AM   #2
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
The cam you literally slide in. Make sure the big lobes have assembly lube smothered on them. When you put it back in make sure the dots on both sprockets of the timing chain line up and put her back together.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old March 5th, 2009, 01:53 AM   #3
89LX347's Avatar
89LX347 will become famous soon enough
what cam are you installing? the best way is ALWAYS to degree it. that makes sure what you have is right to the specifications of what the cam card says, and makes sure it is installed right. degree wheel, dial indicator etc..
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old March 5th, 2009, 01:55 AM   #4
89LX347's Avatar
Comp Cams Cam Degree Kit and Accessories - JEGS
here you go
Old March 5th, 2009, 02:04 AM   #5
chickenbot's Avatar
1990 mustang gt
eventually
tfs 1
1990 gt 5.0
3.55 gears
Old March 5th, 2009, 02:10 AM   #6
89LX347's Avatar
with a cam like that, and alphabet cams alot of people just stick it in and go and thats fine but if it were me i would degree it just to make sure. you never know if all the other variables are correct. timing marks, sprocket on crank etc..
Old March 5th, 2009, 03:50 AM   #7
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
Make sure to get a puller for the harmonic balancer, if not that could put a hault to your project.....
Old March 5th, 2009, 04:27 AM   #8
chickenbot's Avatar
1990 mustang gt
eventually
already got one thx
1990 gt 5.0
3.55 gears
Old March 5th, 2009, 12:46 PM   #9
Correct valve springs?????????????
PeteAndersonRacing.com
Old March 5th, 2009, 05:58 PM   #10
chickenbot's Avatar
1990 mustang gt
eventually
which would be.....
1990 gt 5.0
3.55 gears
Old March 5th, 2009, 08:48 PM   #11
Originally Posted by chickenbot View Post
which would be.....
You tell me...
Old March 5th, 2009, 08:57 PM   #12
1989 LX coupe 5.0L
89lx is on a distinguished road
Trick Flow® Valve Spring Upgrade Kits: TFS-2500100 - trickflow.com
they say you should put new push rods in to Trick Flow® Chromemoly Pushrods: TFS-21406250 - trickflow.com
Threads Similar to: cam install
Cam install usafimj 2005 - 2010 35 March 4th, 2010 06:01 PM
cam install jerseymike Modular Mustangs 17 June 27th, 2009 06:47 PM
CAM Install MineralGreyGT 99-04 50 February 9th, 2009 07:55 PM
cam install? Jucostud 2005 - 2010 23 October 12th, 2008 09:44 PM
Cam install ?'s pfcbrook 99-04 12 February 29th, 2008 08:11 PM
