ignition upgrades?
what, if any advantage would i get from something like the MSD 6al ignition control box on a slightly modified motor? U.D. pullies, exhaust, no major motor mods. Also what about the "blaster" type aftermarket coils?
Leave the stock ignition. The stock igntion performs very well until you get into big horsepower.
so for small tiome and not even racing much spend that $200+ elsewhere?
"It's the fastest who gets paid... and it's the fastest who gets laid" - Reece Bobby |
but if you get the msd, you get to say that you have one of those, and not to mention it looks better under the hood, and it helps a lil' as far as fire goes
94' cobra trickflow upper & lower intake, luntia cam, afr 185cc, trickflow 65mm throttle body/ spacer, b&m short throw shifter, detroit lockers, 3.73 ford racing gears |
#5 | |
i agree with Darrell because i spent almost $600 on the 6AL, dizzy,coil and wires and basically all i have to show for it is pretty red stuff and an adjustable rev limiter.so unless its stroked or blown, save your money. but thats just my opinion....
Go Tarheel's, your our men, if you can't do it!!!............................................. ...............................DAMN!!?? |
I stand behind MSD ignition systems. It would be an awesome upgrade and very noticable. You will feel your car running stronger, it will basically take 1 sec. off your track time doing the 6al system, blaster coil, and I would also suggest a billet Distributor. You won't be let down. That ignition set up along with cold air intake, headers, etc. will be a great start.
1990 GT Convert
93 Notch are you serious? 1 sec? The stock Ford ignition is just fine on a almost stock motor as Darrell said! You need more fuel or compression to outdue the stock ignition! With your theory I suppose each sticker is worth 1/10th of a second also and maybe chrome is 1/2 second? Get real!
Maybe he should just run split fires and a tornado before his M.A.F sensor and he could be in the 10's?!
#9 | |
Bullshit.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
#10 | |
1990 GT Convert
He forgot to mention that he also runs splitfires! thats where the extra umph comes from :wink Shoot if the 6 box is worth a second might as well go with a 7 box and be in the single digits with a stock longblock!
speaking of splitfires, i have been told that mustangs "run like shit" (comparitively speaking) on ANY type of plug but motorcraft. is there a popular brand or is that true? i haven't had mine long enough to know. i know plugs are probablty like anything else, you get what you pay for, but platinum plugs are all expensive, so could you use a performance brand?
#13 | |
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
NGK V-Power copper plugs have always worked great for me..
i am a dumbass
but i thought if platinum was what came in the motor ( '95 5.0) that was all you could use? thats what i was told anyway.
1990 GT Convert
Platinum is only for longer plug life. As far as I know.
#17 | |
ok, last time i make that mistake! thnks for the info
Threads Similar to: ignition upgrades?
| MSD ignition? | energiesource | 99-04 | 2 | August 3rd, 2007 06:41 PM |
| msd ignition | notsoslow50 | 5.0 Mustangs | 2 | July 23rd, 2007 06:27 AM |
| msd ignition ? | 1st fox body | 5.0 Mustangs | 4 | July 6th, 2007 12:19 PM |
| MSD IGNITION | mightyb28 | General Tech | 2 | March 13th, 2007 09:27 PM |
| Ignition! | FaStStAnG5-0 | General Tech | 0 | September 11th, 2006 02:14 PM |
