header bolts
Ok. There has to be an easier way of removing these dam things. I have aftermarket headers and it seem like the bolts are literally touching the tubes. I get approx 1/8 turn on the bolts before the wrench taps the tubes. Any suggestions?
1990 mustang gt
eventually
pix?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
98 Cobra
i used a deep socket to get to mine, or buy hex head bolts
sorry no picks. i am work right now. There is absolutely no way i am getting any sockey on the heads of these bolts. i have to use an open end wrench to slightly move them
1990 mustang gt
eventually
fingers?
1989 mustang gt
8th 5.70
ratchet wrenches are what I use on mine but its still a bitch
i had to use my fingures, now i can barely type.
there is no way of getting a ratchet wrench over the bolt heads. it literaly a "C" hair away from the tubes |
1989 mustang gt
8th 5.70
yours must be different from mine try getting a cheap deep well socket and taking a grinder to the outer edge to make it thin. you could at least run the bolt in like that and then tighten down on it with a wrench
1988 Mustang gt
Lookin for 11's this summer
I have locking header bolts with the allen set screw in the middle...All i have to do is loosen the allen and i can turn the bolt out with my fingers as the allen is what locks it in there
Just a 302, How fast can it be????
1989 mustang gt
8th 5.70
1988 GT
+1 on locking header bolts, finally fixed my problem of going through header gaskets like I do cigs.
1989 mustang gt
8th 5.70
yeah man this is how mine are, it just takes time
weeee foooord!
when i get them off, i was thinking of taking a ball pein hammer to the headers to give a little more clearence. think there will be any performance probs.
naw, just dont get too carried away.
weeee foooord!
1989 mustang gt
8th 5.70
that maybe why mine have more clearence......from the people who had it before me
you have to unbolt the ones the will come off easily first. then take the hard ones out one wratchet at a time and pull the header back with it, so the tube wont rub on the bolt.
i figured it out. I took the smallest diameter socket i could find, ground the shit out of her, and hammered it on, that god, they all came out easily.
you can manipulate the tube a little, but like bean said, don't go crazy
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
2008 Hammock Rodeo Champ
had the same issue myself. till i cut the heat wrap off. took me about a half hour to figure out if i cut the heat wrap off, i'd have more clearance.
i have no mustang. so don't listen to anything i say. |
Threads Similar to: header bolts
| Header bolts... | njstang | 99-04 | 22 | February 28th, 2009 09:33 PM |
| Help with header bolts - Locking header Bolts? | Rush | 94-95 | 4 | February 4th, 2009 04:37 PM |
| Header bolts and gaskets | Ugmul | 99-04 | 6 | February 14th, 2008 09:33 AM |
| header bolts | Blk01ponyGT | 99-04 | 2 | January 5th, 2008 03:26 PM |
| Stage 8 header bolts | Tony_90fox | General Tech | 3 | February 28th, 2007 02:44 AM |
