droped valve
Old March 11th, 2009, 09:43 AM   #1
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
droped valve
at the track saturday and had a nitrous explosion and droped a valve. 351 cleavland stroker 377. Second time this has happend, should I give it one more try or go the cheaper way with the Windsor?
Old March 11th, 2009, 10:00 AM   #2
1998 Cobra
13.24@105.66
Use those cleveland heads, put it on a windsor block with a funnel web intake.
weeee foooord!
Old March 11th, 2009, 10:06 AM   #3
chriswao's Avatar
1989 mustang gt
8th 5.70
I dont want to loose the power I make with the cleveland tho. Im maken right at 700 hp to the flywheel........or was
Old March 11th, 2009, 10:10 AM   #4
chriswao's Avatar
1989 mustang gt
8th 5.70
but If its gona happen again then I might as well build the cheaper one and take a lil loss
Old March 11th, 2009, 10:13 AM   #5
1998 Cobra
13.24@105.66
what power will you loose? It's the same cyl heads, on the same cubic inches. If anything youll make more power.
weeee foooord!
Old March 11th, 2009, 10:17 AM   #6
chriswao's Avatar
1989 mustang gt
8th 5.70
but can the windsor block hold the horse power that I was maken with the 300 shot of nitrous?
Old March 11th, 2009, 10:22 AM   #7
1998 Cobra
13.24@105.66
can a stock cleveland block? I doubt it
Run a dart block.
weeee foooord!
Old March 11th, 2009, 10:26 AM   #8
chriswao's Avatar
1989 mustang gt
8th 5.70
Im not haveing any prob with the block its the aluminum four barrel closed chamber heads that are giving me prob
Old March 11th, 2009, 10:28 AM   #9
1998 Cobra
13.24@105.66
well then you need to either change the compression ratio of the motor, or the style of nitrous your using.
I assume your hitting it with a cheater plate?
weeee foooord!
Old March 11th, 2009, 10:30 AM   #10
chriswao's Avatar
1989 mustang gt
8th 5.70
yea right off the trans brake, one gun
Old March 11th, 2009, 10:37 AM   #11
1998 Cobra
13.24@105.66
That's harsh man.. Honestly You should look into some better springs and adding more ptv clearance if your going to be spraying it that hard.
Can you give me a list with your full setup?
weeee foooord!
Old March 11th, 2009, 10:58 AM   #12
chriswao's Avatar
1989 mustang gt
8th 5.70
four bolt main 351 clev, aluminum heads 4 barrel closed chamberd heads, 377 stroker kit from jegs, pop top forged pistons, 730 lift nitrous cam, jessel rods lifters crane lifers and retainers, Forged Crankshaft, single plain sheet metal intake holly 750 double pumper, c4 with trans brake, digital 6 msd, blaster 2 coil, msd dist, long tube crook headers
Old March 11th, 2009, 10:58 AM   #13
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
Make more power not even close, a stock 351C block can hold 1000hp , heads flow as good as any windsor out there.You just need to work out you nitrous problems and double check yourvalve train springs,keepers,retainers,ect.
Old March 11th, 2009, 11:04 AM   #14
chriswao's Avatar
1989 mustang gt
8th 5.70
so you think its in my nitrous? maybe I sould put it back together like I had it and run two stages? I didnt think windsor blocks could hold as much
Old March 11th, 2009, 11:22 AM   #15
89LX347's Avatar
89LX347 will become famous soon enough
what are you talking about? just cause he has a lot of nitrous doesnt mean he needs bigger ptv clearance, especially if you dont know his cc ratios, or his flycuts anyway. and clevelands are WAY better than windsors
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old March 11th, 2009, 11:24 AM   #16
89LX347's Avatar
why did you have a nitrous explosion? rev it too high and hit the limiter? might look into a window switch.
Old March 11th, 2009, 11:27 AM   #17
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
wud some stiffer springs help?
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old March 11th, 2009, 11:55 AM   #18
chriswao's Avatar
1989 mustang gt
8th 5.70
What Im thinking happend is right after the 60 foot I had to have got into somthing on the track and got on the rev limit but I never herd it till the explosion. It got the cylinder wall pretty bad and the head is gone, spark plug looks like a dime now freaken sucks. it wasnt even a race i was in test n tune
Old March 11th, 2009, 12:15 PM   #19
1998 Cobra
13.24@105.66
Not arguing clevelands arent superior, they are in many many ways. He just asked about going to a windsor block because of the cost effectiveness. If he's going to be spraying that hard out the gate, a little extra ptv clearence wont hurt anyone.. Nitrous does some weird shit sometimes.. I would reccomend putting it back together with the best damn valve springs you can buy.
a 2 stage kit would probably help..
weeee foooord!
Old March 11th, 2009, 12:16 PM   #20
Im guessing its valve train issues.....bad springs...the explosion was the valve dropping not nitrous
PeteAndersonRacing.com
Threads Similar to: droped valve
If I only had a 4 valve...... 97S281 4V / SVT 7 March 1st, 2009 09:58 PM
5.4 4 Valve 330CubeGt Videos 2 January 11th, 2009 11:27 PM
5.4 2-valve stanglifemike 96-98 18 August 4th, 2008 01:25 PM
2v into 4 valve? SteviGX 99-04 40 March 21st, 2008 01:38 PM
Egr Valve And Pcv Valve Delete? Jeffery9508 V6 Mustangs 16 January 28th, 2008 09:45 PM
