suspension questions
i need to re-do the entire suspension, dont know anything about suspension so i was hoping to get ideas on a whole kit, not looking to spend too much i just want better ride, better cornering and something that isnt 20 years old
and recommend a good k member
if you were on a bicycle and we were going up hill i could beat you in a race |
UPR products FTW
hoping for specifics? i want a kmember so should i get a kmember kit for the front and then a rear suspension kit
if so what are good combos what all should i replace i know it is old and ratty and neglected will be looking to buy and pice together tell i have a full kit so what shoudl i look to get
AJE or team z front end kit
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1988 Mustang gt
Lookin for 11's this summer
UPR k-member and upr rear setup
Just a 302, How fast can it be????
why do you want to get a kmember? oil pan too big? car too heavy? other than that, you dont need one
What are the goals for the car? Do you wanna take corners well or launch good? Or do you want something in between?
If you're not going to be competing with the car and it's just a daily, a Kmember isn't necessary, more of a luxury you could say. Upper and lower rear control arms are always a good bet with suspension and also a set of subframe connectors if you're going to be beating on the car at all. Again, we can give specifics, but you have to too
![]() 03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot May it R.I.P. New whip: 1953 Ford Mainline Coupe... let the games begin! |
Priest of the Car Gods
+1 on the goals. A corner carver is going to have VERY different needs than a 1/4 mile car.
If you want a kit that will work together and to not have to think about matching components, go to Maximum Motorsports, and buy the best grip box you can afford. They start around $1k, and go up past $6k depending on how serious you want to be. Maximum Motorsports :: The Leader In Mustang Performance Suspension
#9 | |
85 GT/86 SVO/2010 GT500
i dont race 1/4 mile its a daily driver,
but i drive it very hard and very fast, so i wouldnt say i am worried about launch , im more into cornering and even tho i don't race i like shaving weight off the car, i like the idea that the mods i have and will b e getting will be pushing as little weight as possable, and also i have been told a kmember would make it easier to work on, which is big to me because i am a newbie and this is my learning car so i just want something to replace the 20 year old system i have that can handle my daily beatings and corner beautify without being too stiff and uncomfortable because it is a daily driver specific enough right now i am looking at this front end kit MUSTANG-UPR Products.com what else can i purchase along with this kit and what would be a good rear end kit id like to spend less than 700 on the rear end kit
upr's stuff is pretty good it's all chrome moly which is much stronger then stock and much lighter. Aje is the lightest while maximum motor sports is the heaviest from my experience but mm's is geared towards oval track usage where as pretty much all the others are geared towards weight loss while being stronger then stock. mm's requires you purchase there whole front end kit which is pricey, others like qa1 you can reuse your stock a arms.
I'll tell you this, i've used upr, qa1 and team z tubular k's in the past and any of them are good. They shed allot of weight and really open tons of space allowing you to get to pretty much anything from under neigh. Install isn't too bad neither. |
Yes, specific enough.
Get the UPR K-memeber front kit with the coilovers, etc. Probably should stick with the 250 spring rate. For the rears, I would just stick with UPR (they may give you a great package price for it). For uppers, best bet is a double adjustable with a poly bushing. Spherical bushings can sometimes be a bit aggressive for street use. MUSTANG-UPR Products.com For lowers, there's either the solid lower from UPR: MUSTANG-UPR Products.com Or, if you don't mind spending a little more, Max. Mot. has the "weight jacker" type lowers. I run them and love them. HD Adj. Rear Lower Control Arms, 1979-98, with swaybar mount [MMRLCA-2] - $379.95 : Maximum Motorsports Performance Mustang Suspension Store, Buy Now! If you really want to focus on handling, look into a rear swaybar, strut tower brace and some subframe connectors. There's also the option mentioned earlier, that MM has "grip boxes" that come with different levels of suspension.
Call Maximum Motorsports and tell them what you want to do, there cars handle great, and they are suspention guys
#14 | |
1990 Mustang GT
13.64 @ 101 MPH
if you do a tubular k-member i think your gonna have to do the front coil over setup also. UPR ftw. subframe connectors will be a good addition also. just buy a whole kit and get it over with.
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
2008 Hammock Rodeo Champ
i have no mustang. so don't listen to anything i say. |
1989 Mustang Gt
Run me and find out!!!
#18 | |
You have 2 choices when it comes to the UCAs for a street/handling car: leave them totally stock, including the rubber bushings, or get a system that totally replaces them, such as a torque arm. The triangulated 4-link is engineered such that it requires the bushing deflection of rubber bushings to actually work. Getting rid of the rubbers will only lead to bind, and suspension that's even more unpredictable than it already is.
1988 GT
I have the QA-1 front kit and it's perfect... not that expensive, bolts right in with no problems, I say QA-1.
#20 | |
Hmm...
Threads Similar to: suspension questions
| Steeda Suspension- Suspension Questions | MustangJon255 | 2005 - 2010 | 22 | June 2nd, 2010 05:43 PM |
| Suspension Questions | OhhShorty | 99-04 | 5 | January 18th, 2009 11:52 PM |
| suspension questions | 03 R Code | 4V / SVT | 11 | December 17th, 2008 07:36 AM |
| Suspension Questions!! | bubsdelicious | 5.0 Mustangs | 0 | September 5th, 2008 12:10 AM |
| suspension questions | mustangsoldier | 5.0 Mustangs | 8 | August 7th, 2008 09:46 PM |
