lower intake gasket question....
i have gt40 heads mild port job done alil bigger then stock.. im using a stock ford factory intake that is ported to match the heads. i tried using the felpro 1250 gaskets and seem to be ripping between the bottom of the port and the liftervalley(boosted car). second set maybe 3-4 passes. i was thinking if i can run a stock style gasket but use one from a ford explorer or something that will have a same size port as my heads and intake... any help is appreciated thank you...
1988 GT
I'm not sure if they make them... but, maybe a copper gasket???
1988 Mustang gt
Lookin for 11's this summer
I run Fel-pro 1262 and never had a problem with them
Just a 302, How fast can it be????
1992 Lx
11.39@119.24
weird my last set was the 1250 that i removed today, they were from about a year ago and honestly looked like new
i never had a problem all motor with the 1250's.. as soon as a started to boost it was bad. another car i worked on stock longblock we put stock gaskets and it lasting. only thing my ports are alittle bigger..
1992 Lx
11.39@119.24
pvc system failure?
no pvc system hooked up. just breathers...
Threads Similar to: lower intake gasket question....
| intake gasket ? | Mlx50man | 5.0 Mustangs | 9 | January 21st, 2009 08:53 PM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| lower manifold gasket question | nolife | 5.0 Mustangs | 2 | April 10th, 2008 11:27 AM |
| Question about intake gasket causing pinging. please help. | 04silversnake | 5.0 Mustangs | 2 | October 18th, 2007 04:50 PM |
| lower intake gasket | YNOT | 5.0 Mustangs | 1 | June 13th, 2007 08:09 PM |
