My Lucky Day
Old March 13th, 2009, 12:24 AM   #1
Look Ma! My First Post!
1989 Mustang GT
XLCR is on a distinguished road
My Lucky Day
Hi, folks! New here. I've had an '89 GT for about two years now and have a few mods.
Problem: My garage is filling up with all the stock parts I have now replaced with aftermarket bits.
Solution: I just bought a '79 Mustang Ghia Hatchback for $400. It was abandoned at a repair shop because the owner didn't think it was worth it to replace the brake master cylinder. It needs a little work, but it's really not in too bad a shape. The body is fairly straight, no rust, and all of the glass is perfect. It has an SROD 4-speed and a 302 that was rebuilt at one time. Whoever did it also added an Edelbrock 4-barrel and aluminum manifold.
I'd like to put my stock '89 GT Turbine wheels mounted with 225/60-15 Bridgestones on it. Any clearance problems in front? And I'd also like to add the stock '89 factory headers to it. Any problems with fitting those on a '79? And finally, does anyone know where to get body moldings and interior parts for a '79? I've been getting most of my stuff from LateModel, but they show very little for the early Fox. Thanks!
Old March 13th, 2009, 12:31 AM   #2
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
try this for the interior RockAuto Parts Catalog
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old March 13th, 2009, 12:38 AM   #3
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
shut up before i punch you in the throat
Threads Similar to: My Lucky Day
Got lucky JASonic The Clubhouse 24 February 17th, 2009 11:39 AM
Lucky Sob!!! 93HatchsBFF The Clubhouse 21 November 3rd, 2008 06:25 PM
My lucky streak is over Warlok The Clubhouse 21 January 20th, 2008 08:28 PM
Do u feel lucky? G.T. Rags The Clubhouse 13 October 31st, 2007 01:04 PM
Lucky. Reset The Clubhouse 22 October 18th, 2007 01:54 AM
