Boost Gauge Install: How To
I know this is not the most daunting of tasks but I've had to help three of my friends do it now, soooo since I have a new toy with a V1 I figured I'd do a write up on it.
List of supplies you will need: 1. Boost gauge 2. Light for gauge 3. Vacuum line 4. Vacuum T 5. Vacuum line connector 6. Drill 7. Grommet 8. Black 14 gauge wire 9. White 14 gauge wire 10. Weatherproof butt connectors (for 14 gauge wire) 11. Wire cutters 12. Needle nose pliers 13. Wire strippers 14. Crimping tool 15. Pillar gauge pod 16. Teflon tape 17. Add a fuse connector ![]() 1. Remove stock pillar ![]() 2. Fish black and white wires through edge of dash, about 4 feet of black and 2 feet of white ![]() 3. Put ends of light and new black and white wires in the butt connector and crimp (top side of dash) ![]() 4. Now heat the shrink on the connector for a good seal ![]() 5. You can now test you connection with a 9V battery, so if you have an issue later you know that it's not from here. at this point take the white wire, connect with butt connector to the add a fuse connector and place it in a spot that is only on with your ignition or switch or a switch on. i used the headlight switch so the light will work with the dimmer switch (sorry, forgot to take a picture of this) ![]() 6. Fish the vacuum line through the dash like you did with the previous wires, but sine the line is in a permanent curl position, it is easier to fish a piece of wire through then tape the ends of the wire and vacuum line together and pull the line through ![]() 7. Now you should have the two wires and vacuum line all fished through together ![]() 8. Drill a hole in your firewall/driver-side dash area to fish your wires/lines through (note that if you have a wideband you need to drill big enough to fit the pigtail through) now put the grommet in and pull black wire through. you will see a ground tether to the left, you can use this as your ground. ![]() 9. Take the upper end of your vacuum line and put the end cap and crush piece on the line, these feel tight but they will fit ![]() 10. now put the third piece that screws on to the back on the boost gauge on as well (wrap threads in teflon tape, but be sure not to cover hole) ![]() 11. Tighten ![]() 12. Slide your pillar into place (unbolted) and pull the light and vacuum line through the space you are installing the gauge, be sure none are kinked or bent ![]() 13. Install light in back of boost gauge, as well as the vacuum line, be sure to teflon tape the threads on the back of the gauge ![]() 14. Fish you vacuum line through you new hole and place the vacuum connector on the end of the line (appropriately cut)
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." Last edited by baine21225; March 15th, 2009 at 12:57 AM. |
15. Use the T and tap into a vacuum line
![]() 16. Pull your wires/lines tight as you push the gauge into the pillar and connect the pillar to the car ![]() ![]() If you have any questions please feel free to ask Rep is appreciated
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." Last edited by baine21225; March 15th, 2009 at 12:58 AM. |
1992 Lx
11.39@119.24
nice dude repped, hopefully ill be installing just a single pod for my temp guage... what wire did you tap to light it up? you said the dimmer switch? where could i tap into that?
on my 89 it's fuse number 13, left side of fuse box
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1992 Lx
11.39@119.24
oh shit straight into the fuse box? how did you do this?
thats what the add a fuse is for. . . . it looks like a black fuse that plugs into the place where the original one is, but it has a place for the old one and a new on on top of it, so you just connect your power wire (white wire) to the wire coming from this, and your good to go
1992 Lx
11.39@119.24
ohhhhhhhhhhh shit ive never heard of that, thanks dude you just saved me some frustration prob next saturday
i aim to please
1992 Lx
11.39@119.24
<------------pleased
1989 LX Coupe
Nice write up.
havent seen ya in a while chris, how ya been?
1989 LX Coupe
Been good, thanks for asking. The car had been sitting for a while due to no monies, but recently I have gotten the torque boxes all welded up and I am dropping the car off today to get ready to be painted....
I'll probably put together a thread to show the progress. How've you been y0? Still having problems with those spark plugs? |
been good.....still no new plugs....so i have new msd wires, new msd programable 6al-2, some mega coil.....and the old ass plugs, going to install a new radiator and electric fan today
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." Last edited by baine21225; March 15th, 2009 at 12:15 PM. |
1989 LX Coupe
What heads are on your car? Sounds like you have about an hour's worth of work to tackle.
E7
would anyone be interested on a wideband how to?
87 Mustang GT T-top
Nicely done, if ya dont mind me asking, how long did it take ya 2-3 hours?
I have to redo my Water Temp gauge. it was broken when i got the car....problem is its Mechanical, and i dunno anything really of how these things work and if its fixable..... But nice work, thanks for the post! |
thanks, if your doing it your first time maybe two hours on the long end, its really not hard at all.....i'm installing a new water temp gauge next week so i'll do a writeup on that when it gets here
#19 | |
87 Mustang GT T-top
Also Do you suggest i switch to a Electronic gauge? Or try to find out if i can save mine, i was just wondering, b/c i hear the mechanical ones arnt supposed to be in the car? |
the only mechanical i wouldn't put in the car is fuel pressure, and usually the mechanical ones are a little more accurate and are much less prone to break.....my buddy sells auto meter and says the sending units go up in the electronic on ALL the time
Threads Similar to: Boost Gauge Install: How To
| Boost gauge install | blakehunter316 | 5.0 Mustangs | 17 | January 20th, 2009 10:33 AM |
| How to install fuel pressure and boost gauge?? | Saleenssc14 | 2.3 Mustangs | 19 | July 23rd, 2008 12:48 AM |
| Boost Gauge | beheivjer | 2.3 Mustangs | 10 | May 20th, 2008 02:44 PM |
| 89 boost gauge install.need help ASAP | hot89 | 5.0 Mustangs | 2 | April 3rd, 2008 12:47 PM |
| Boost Gauge | mmvi | V6 Mustangs | 9 | December 26th, 2007 11:30 AM |
