Shafts move, new c-clip's, pin, shaft or all???
Old March 15th, 2009, 05:02 PM   #1
1988 convertible's Avatar
1988
1988 convertible is on a distinguished road
Send a message via Yahoo to 1988 convertible
Hi Guys need some serious help...
I think i need to replace the C-CLIP in the rear diff and the cross pin as they may be worn this has been discovered while installing a rear disk kit to the car, there is allot of play in the shafts moving about 5mm either way... they are making the disks rub on the inner sections on the anodised part of the calliper... i as aware before when i had the drums on there but changing to disks has made it worse...
ive seen some C-clips the Cross pin to buy but will this be enough to stop the movement, or do you think i would need to buy new shafts too???
I have also seen a c-clip eliminator kit but this fits axle shafts 1.400"dia and is not for street racing or use with rear disks...
Has anyone else experienced this when converting the rear drum to disks???
if someone could steer me in the right direction be very grateful
Old March 15th, 2009, 10:19 PM   #2
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
The axles will move in and out slightly. Just pull the diff cover and pull the center pin out and see if it has excessive wear on it. Might as well pull the axles all the way out and inspect the C-clip grove and make sure it is not worn out to badly. C-clips generally hold up fairly well, but anything can happen.
Old March 15th, 2009, 10:55 PM   #3
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah 5mm doesnt sound like excess movement
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old March 15th, 2009, 11:48 PM   #4
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
Thats about right. Not much you can do.
Old March 16th, 2009, 06:56 AM   #5
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
or just get some c clip elims
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old March 16th, 2009, 09:19 AM   #6
1988
ok im gonna try the c-clips and a new cross pin... will check for wear too...
the eliminator only states that you can use them for racing use and without disk brakes...
is there any specific reason why i cant use the eliminator???
Old March 16th, 2009, 11:11 AM   #7
flamestang's Avatar
flamestang is on a distinguished road
do you want to sell your backing plates you took off?
Old March 16th, 2009, 02:29 PM   #8
ryans88gt's Avatar
probably due to the trac lok being worn out. When you rebuild it that sets the end play as the shims in the trac lok move the side gears in or out.
Old March 17th, 2009, 03:56 AM   #9
1988
im not too familiar with this sect... is it possible to repair or replace the track lock???
trying to cover all the bases, so i welcome anymore possibilities!!
Old March 17th, 2009, 03:58 AM   #10
1988
Hi sorry the guy that helped me fit the brakes claimed them when we did it lol... he didnt take any payment but i let him have some spare bits and things
sorry
Old March 17th, 2009, 01:10 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Play in the axles is normal with c-clip rear ends.
Old March 19th, 2009, 03:24 AM   #12
1988
Hey Guys thanks for the help with this...
ive had a few people mention the trac-lok as well...
so ordered a repair kit for the trac-lok, c-clips, centre pin...
gonna see how things go with that and also check the wear on the shafts when i take it all out...
Thanks for all your help and ill post back how things get on!!
Threads Similar to: Shafts move, new c-clip's, pin, shaft or all???
How to: Swap axle shafts AZAlloy 2005 - 2010 4 April 17th, 2009 08:49 PM
drive shaft shop one piece steel shaft ok for automatic tran mustang fanatic 2005 - 2010 8 September 24th, 2007 01:21 AM
drive shafts 40thmustanggt American Muscle 2 August 8th, 2007 04:19 PM
drive shafts hopper 5.0 Mustangs 7 July 3rd, 2007 01:15 PM
are 4 pin vs 5 pin relays the same OTreborO 5.0 Mustangs 3 August 21st, 2006 01:24 AM
