289 heads on a 302 - Forums at Modded Mustangs
post #1 of 20 Old March 18th, 2009, 03:13 PM Thread Starter
britishmartin's Avatar
Thumbs down 289 heads on a 302
Hello
I have been looking in my ford engine book and it says, if you put 289 heads on a 302 it adds 1 point to the compression. This sounds good to me as i dont have to change the pistons to up the CR.
But was wondering if anyone has put a set of 289 heads on 302. And had good results.
I know hypos are very good, but very expensive. But would a set of 289 heads that have had same size valves as 302 fitted, then ported and scimed.
Work better than these 87 smog piped 302 heads.
If any one has done this or know some one whos done this please let me know good/bad points it would be grate.
Cant afford trickflows or any other alli heads.
Thanks
britishmartin is offline
post #2 of 20 Old March 18th, 2009, 03:45 PM
mustangsoldier's Avatar
try to find a set of gt40p heads off an explorer, you'll have MUCH better results. and not to expensive...
shut up before i punch you in the throat
mustangsoldier is offline
post #3 of 20 Old March 18th, 2009, 04:23 PM
coreyflipp's Avatar
and get the upper/lower intake while youre at it
2002 gt 5-speed slow
1990 gt 5-speed junk
coreyflipp is offline
post #4 of 20 Old March 18th, 2009, 09:13 PM
M L Struck's Avatar
Not true!
he said with the same size valves as a 302/ then the 289 with smaller chambers and bigger ports would be better
M L Struck is offline
post #5 of 20 Old March 19th, 2009, 12:55 AM
nevermind breezed over it and didn't see that....
post #6 of 20 Old March 19th, 2009, 09:58 AM
coreyflipp's Avatar
E7TE have 1.78 valves. GT40p's have 1.84's. I think the gt40p's outflow the 289's also. I would go with the gt40p head. You can always mill them down to get more compression too
post #7 of 20 Old March 22nd, 2009, 10:08 AM Thread Starter
Thanks guys.
I want as big a valves as posible, with highest compresion, so thats grate.
sound
post #8 of 20 Old March 22nd, 2009, 11:36 PM
Adding E6 heads will raise your compression.
Just kidding, but it will add compression, just has very poor performance.
GT40P heads like mentioned above, will add hp/tq and raise your compression. But, you'll need special headers, since the spark plug angles are different.
50fanatic is offline
post #9 of 20 Old March 23rd, 2009, 09:09 AM
1slo5.0's Avatar
Yes, P heads are probably the best flowing factory Windsor head. I'd take a set of P heads over 289 heads any day.
1slo5.0 is offline
post #10 of 20 Old March 23rd, 2009, 07:54 PM
**Chris**'s Avatar
What about a set of 289 heads that are very professionally ported (to match a 1262 intake gasket) with 2.02 valves and matched to a worked over Edelbrock Air Gap carbed intake ported to a 1262 gasket as well as some runner and plenum work?
Just bought the intake today, a different guy has the heads w/ 1.6 aluminum roller rockers and two brand new Fel-Pro 1006 head gaskets for $650... springs are good to .560 lift.
I need to pull the trigger on this soon... If I do it all all.
**Chris** is offline
post #11 of 20 Old March 23rd, 2009, 07:59 PM
**Chris**'s Avatar
*edited*
The guy was not naturally aspirated, he was running a 200 shot to get the 6.9's.... My car would run that with my heads so nevermind on that.
post #12 of 20 Old March 24th, 2009, 08:56 PM
1slo5.0's Avatar
Measure the valves. I bet they are 1.94s. We've tried to put 2.02 valves in several factory Ford heads and they are too big if you put a 1.60 exhaust valve in. Those heads should work pretty good if the port job is good. I'd ask for a flow sheet with the heads so you know where they are at. Without knowing what they flow you are shooting ducks blind folded.
1slo5.0 is offline
post #13 of 20 Old March 24th, 2009, 10:08 PM
**Chris**'s Avatar
Thanks Darrell.... he said the valves are 2.02's but I have been told that valves that big will not work with stock pistons so being told that you are more than likely right about them being 1.94's since he said the pistons were stock.
He also told me that they are not ported to match the 1262's (there is just not enough material to make them that big)...but that I would have to use the 1262's.
I'm getting conflicting info on all sides.... and for the money, I think I'd rather wait until I know for sure what I am buying.... I don't understand the "twisted wedge" heads, my one Mustang car shop guy said the Twisted wedge heads are the only heads that can run a true 2.02 valve with stock pistons and that not even AFR 185's would work.
What does twisted wedge mean?
post #14 of 20 Old March 25th, 2009, 01:55 AM
1slo5.0's Avatar
Twisted Wedge is a patented design by Trick Flow. Probably the best bang for the buck in a small block Ford head. Personally, I'd stick that $650 that the guy wants for the 289 heads toward a set of Trick Flow heads. You will be much happier with the investment.
1slo5.0 is offline
post #15 of 20 Old March 25th, 2009, 02:30 AM
Smirnoff's Avatar
the twisted wedge heads rotate the valves position in the combustion chamber so you can use a 2.02 valve with the stock pistons
Smirnoff is offline
post #16 of 20 Old March 25th, 2009, 02:37 AM
Yeah Twisted Wedge heads are a better bet. but remember you will need to buy New Roller Rockers, the ones for the Trickflow heads are different from your normal head RR's.
The Novice is offline
post #17 of 20 Old March 25th, 2009, 01:35 PM
1slo5.0's Avatar
Says who? I've been running Trick Flow heads for years on multiple engines and never used any special roller rockers. If you run shaft mount rockers then there is a specific shaft set up for almost every individual head out there but for a basic roller rocker, they are interchangeable between twisted wedge and conventional heads. Unless some companies are selling twisted wedge specific roller rockers now as some sort of marketing scheme. I've never had any valve train geometry issues so I can't see why there would be a specific rocker unless it was just a marketing issue.
1slo5.0 is offline
post #18 of 20 Old March 25th, 2009, 03:30 PM
jack90gt's Avatar
Aren't the pushrods different on twisted wedge heads though?????
Just a 302, How fast can it be????
jack90gt is offline
post #19 of 20 Old March 25th, 2009, 03:51 PM
1slo5.0's Avatar
Yes, the push rod length is different.
1slo5.0 is offline
post #20 of 20 Old March 25th, 2009, 05:56 PM
**Chris**'s Avatar
Thanks for the info Darrell.
Human Verification
