no heat
Old January 14th, 2007, 11:48 PM   #1
hmotes is on a distinguished road
no heat
My car doesn't get past 130 on the stock guage unless I run my car then letting it idle for an hour, then it begins to warm up. I just install a 180 t-stat from mr. gasket, and i still have the stock clutch fan. I know my guage works cause my car overheated, and that how i found out the hour thing. Any idea what might be the problem. I really would like my heater blowing out hot instead of warm.
Old January 15th, 2007, 12:53 AM   #2
Stangzilla's Avatar
Stangzilla is on a distinguished road
Just to be sure the gauge is accurate change the temp sensor
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old January 15th, 2007, 01:59 AM   #3
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
I wouldn't trust the stock guage for crap. Find another way to check the temperature - an infrared thermometer would do the trick, or if you can find something that goes to atleast 210*.
Old January 15th, 2007, 09:24 AM   #4
Stangzilla's Avatar
Old January 15th, 2007, 12:10 PM   #5
i seen my guage go upto 270* when the car overheated.
Old January 15th, 2007, 01:08 PM   #6
What does "overheated" mean?
Do you actually blow a head gasket? Was there steam coming out of a hose or the radiator? Or did the needle just go really high?
Old January 15th, 2007, 01:33 PM   #7
the needle went high and the overflow hose blew off.
Old January 15th, 2007, 01:46 PM   #8
Still doesn't mean much to me. Get something to accurately measure the water going in and going out, then bring us the numbers. There is no way in hell your block is running 130*. My guess would be that your problem is somewhere in the heating system itself.
Old January 15th, 2007, 05:24 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is the heater core plugged? If coolant can't circulate thru the heater core it won't blow any warm air. Do the radiator hoses get hot? If they do get hot you know the car is getting up to operating temperature.
Threads Similar to: no heat
driving a V-6 in the heat JASonic V6 Mustangs 19 May 7th, 2007 07:42 PM
Heat Release snailstang 96-98 1 February 16th, 2007 10:51 AM
Heat Plates ThePonyExpress V6 Mustangs 16 February 12th, 2007 01:57 PM
Heat / Air terribleonexx88 5.0 Mustangs 3 October 19th, 2006 01:09 AM
Please help with the heat tdurbin 5.0 Mustangs 12 May 19th, 2006 12:15 PM
