So...so confused
Old March 22nd, 2009, 10:05 PM   #1
87 GT
14.2@98.something
darkhorse50 is on a distinguished road
So...so confused
I finally am sending my gt40 heads out to the machine shop. I need to know a good spring kit to run on these heads, what kind of valve seals should I run "if I even need new ones" or if anything else needs to be addressed. Im trying not to sink a bunch of cash into these heads. There are so many damn options out there, its made me really confused. Ohh and one more thing that has even confused me more, I'v been told I need to run a seat pressure of atleast 130lbs on my cam COMP CamsŪ - Cam Details
Some one please help
Old March 22nd, 2009, 10:09 PM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
tell the machine shop the cam and if they are any good they can tell u the spring u need. also you want VITON valve seals and yes replace them they are only 20.00 and come with the valve job.
<font size=4><b>MILITARY CREW
Old March 22nd, 2009, 10:16 PM   #3
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
+1 if your shop is any good they will hook you up with the correct parts and a good price
Old March 23rd, 2009, 10:18 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you do the job correctly you are going to have cash stuck in the heads. At minimum the heads will need to be surfaced, valve job, valve springs, seals, retainers and locks. There might be some bad valve guides and valves too. I'd make sure the machine shop checks all of the valves and guides closely so you don't run into problems down the road.
Old March 23rd, 2009, 01:30 PM   #5
87 GT
14.2@98.something
thanks for the input guys, I forgot to ask, Double valve springs require more machine work correct? The valve spring outer diameter for these heads is 1.40in??? and the valve seals are .500in diameter in the shoulder?
Old March 23rd, 2009, 02:54 PM   #6
Here you go sir
Spring UPGRADE !! More than just sticking them in there.....
PeteAndersonRacing.com
Threads Similar to: So...so confused
I'm a little confused... D-Brow General Tech 4 July 26th, 2007 08:25 PM
Ok, confused about this: shroom 99-04 61 April 1st, 2007 06:30 PM
confused joeymellin General Tech 0 March 11th, 2007 09:23 PM
somewhat confused sirpullsalot General Tech 4 January 16th, 2007 11:12 PM
