2008 Hammock Rodeo Champ
Trick Flow intake
Should i get this?
![]() and if i do, should i go ahead and bolt it on, or just wait for heads and a cam? they should be coming in the next few months (maybe). p.s. my engine is bone stock. only mods: Hooker shorties, Mac O/R H, Mac catback, 3.73's. oh and no smog pump.
i have no mustang. so don't listen to anything i say. |
ummmmmm, depends what the price tag is
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
under 3
87 Mustang GT T-top
Under $300, thats not bad, mildly used ones go for about 325-350 around here, if its in good shape i say go for it. But depends a little bit, what Cam and Heads are you getting?
Either way i would prob wait till ya get your other stuff to at least put it on, imo, just doing double work and you wont notice a lot of diff. with everything else stock, i would also suggest in upgrading the fuel system when ya do the H/C/I swap, if ya havent already. But for the price i would. |
im looking into a trickflow h/c/i what fuel system should i look into, i want a 225lph fuel pump what size injectors should i get
if you were on a bicycle and we were going up hill i could beat you in a race |
#6 | |
any suggestions on heads and a cam would be appreciated. and, i've heard that the stock fuel system shouldn't be a concern until making like 400+ HP. maybe i read that wrong. but, i'm sure i'll do it anyway. waht would you guys suggest? like a 255 pump and 30#'ers?
i have no mustang. so don't listen to anything i say. Last edited by Squints; March 25th, 2009 at 10:26 PM. |
#7 | |
87 Mustang GT T-top
Well if the block is out of the car, why not try to pull it out and see if ya can get a part # or something? at least worth a shot so you know what your working with. Im no expert, and i dont pretend to be, but i would think that its really not all about the parts rather than a good combo. Obviously Trick flow for example says with there full kit (170cc heads, Stage 1 cam and TFS intake) they dyno a 306 to 370 HP. Now note that thats with all the supporting mods, but thats pretty decent for a 5.0. N/A. But its really up to you depending on how much money you can spend a lot of people here would say TrickFlow, or Canfield but those are bigger heads and you would want a more aggressive cam to get the flow#'s. Another thing is since you have the block out, you could just Bore it out and get a 347 Stroker kit and throw some heads on with that intake? But before we get caried away.... Whats your Budget and what are your goals for this car. HP Numbers, What will it be ( DD, Track only, street rod and so on )? Its always good to set some goals and most importantly a budget, b/c no one wants to start a project and not be able to finish it b/c of finances. Again im no expert, just trying to help. |
as of right now, i have a pretty much stock 91 notch. engine in it, running and it's good to go.... just stock.
the engine that's in my garage came out of my other car that i sold. i've thought about building something out of it. bt i don't know if i want to take that on right now. budget..... not really setting a clear number, but, i'll be saving as much as i can. and if things work out, i should have an extra 30-35 grand in the bank in the next year. so, that should pretty much cover me as far as the budget. i tried to get the cam out, but couldn't get it to move. do i need a puller or something? my DD is a honda accord. so, this car is just for fun. sunny days and maybe a trip to the track every once in a while.
i have no mustang. so don't listen to anything i say. Last edited by Squints; March 25th, 2009 at 10:46 PM. |
#9 | |
87 Mustang GT T-top
i edited
![]() see above post again. as far as HP goals, i'd like to see 300+ at the wheels. nothing too fancy. maybe put a 100 shot on it for the track. not too crazy.
i have no mustang. so don't listen to anything i say. Last edited by Squints; March 25th, 2009 at 10:50 PM. |
stock fuel pump sucks, get a 255, simple swap.....i'd pick it up if its clean and under 300
and dont forget that if you swap injectors you also need a calibrated maf
#13 | |
#14 | |
87 Mustang GT T-top
Well to me 300+ at the wheels is a lot. I was doing some research and i found people who did the top end Kit from trickflow ( with all its supporting mod ) Most of them made about 285-295 RWHP. So if you want more HP, i would say either get larger Trick flow heads and a bigger cam, or Canfield heads (190+cc) and they are cheaper than the TFS equivalents. And ya could always go Custom Grind cam, def. would get your money out of your combo their. Or depending on how old your block is ( how many miles are on it and if its not in the best shape ) You could Get a 347 Stroker kit for it, pistons, Stroker cam and so on, they start at about $800 at FordStrokers.com 331-347-393-408-418-427 stroker kits and ford parts. And then ya could get some nice heads and im sure you would be damn happy there. Btw do you have gears in your rear end, those are some of the best mods you can do on these cars. really makes a big difference, imo. |
3.73's in it now. but i'm putting a 4.10 in it. it's an AOD. but WHEN that takes a dump, i'll put in a C4 or something.
and yeah, when i still had the 86, i spoke to woody about a 347 shortblock. so i'm familiar with his stuff. if i went with a stroker, i'd more than likely be dealing with him.
well, 300+ is a goal. not necessarily how far i'll be going. but, you never know. if i get that big fat pay check, i think i'll be looking at more than that. but for now, i'm sure i'l be happy with whatever i can get out of good H/C/I.
#17 | |
#18 | |
1988 Mustang gt
Lookin for 11's this summer
Man i have a buddy selling a brand new intake identical to that in the box for $350
Just a 302, How fast can it be????
#20 | |
Threads Similar to: Trick Flow intake
| Trick Flow Intake Manifold | LeadFoot_GT | 99-04 | 0 | May 20th, 2007 02:50 PM |
| Trick Flow Intake | MustangMatt96GT | Modular Mustangs | 16 | May 13th, 2007 06:10 PM |
| trick flow intake | Fastpitchdad | 5.0 Mustangs | 6 | December 9th, 2006 03:08 AM |
