vacuum problem
ok i have 302 with trick flow R intake on 351 heads no my problem is that i have a vacuum line that comees off the front of my upper intake that use to go to my EGR valve i think b/c i dont have an EGR any more i tried to plug the line but the car and the car stalls what should i do hook it up to the tree of vacuum lines
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
all motor
92 coupe
9.94@136.40
does that hose pull a vacuum?
Run the hose from that egr to your vacuum tee and see what that does
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
Threads Similar to: vacuum problem
| 94 5.0 vacuum problem > Please Help! | Alexander79 | 5.0 Mustangs | 1 | September 14th, 2007 09:34 AM |
| Idle/vacuum problem | FiveOOH89 | 5.0 Mustangs | 1 | August 7th, 2007 01:58 AM |
| vacuum... | sivart | 5.0 Mustangs | 22 | July 31st, 2007 11:02 PM |
| vacuum line | 96gtponyred | 96-98 | 1 | July 22nd, 2007 12:56 PM |
| Vacuum Hoses | shade tree | 5.0 Mustangs | 2 | September 9th, 2006 01:03 AM |
