#21 |
1985 Mustang GT
200* is getting hot. oil begins to burn at 212*. 170 to 180* is normal operating temp. if your thermo is a 180* it'll open fully at 180* and will hover right around their. an engine that is cooled too much will not perform as well, oil will be thicker. 155* to 185* is prime.
#22 | |
87 Mustang GT T-top
#23 |
1985 Mustang GT
#24 |
1991 mustang 5.0
My gauge must not work. According to it, my car never gets even 1/4 of the way up the gauge. Don't know what temperature that is
#25 | |
#26 | |
1985 Mustang GT
HTML Code:
http://wiki.answers.com/Q/At_what_temperature_does_oil_burn to me it makes perfect sense that if oil burns at 212*, have the coolant cool at 180* or less. 212* is hot...stick your hand in boiling water once and tell me its not hot.. Last edited by viperlocc; March 28th, 2009 at 06:48 PM. |
#27 |
1992 Lx
11.39@119.24
i dont think turbos are only ran at 212 degrees, all that oil cooling them must be bad in 5 min
#28 | |
Well oil does not burn at 212. The flash point is the point that the fumes given off can combust and the flash point is also considered the point where oil starts to break down. Maybe I'm confused by your reference comparison of burning and flame, do you mean maybe there is a chemical change in the oil at 212 because that does not happen at that low temperature either. The point the oil will actually burn is even higher than the flash point (autoignition point). Either way, temperatures in the cylinders and other points in the engine where oil flows is FAR hotter than the 150-210F coolant anyway. Maybe the people you asked misunderstood your question.
Flash point - Wikipedia, the free encyclopedia
They make thermostats at different temperatures because that is what that specific engine was designed for. The more I read this thread, the more confused I am by your questions.
#29 |
1985 Mustang GT
well i might have been a little off with the oil but it still doesnt beat the fact that temps over 200* are still bad for an engine. always thought something different with oil but guess ya learn new things everyday
Threads Similar to: Will this kill my battery?
| Battery Kill switch | GreenFaleen | Audio/Video | 3 | June 8th, 2007 01:55 AM |
| battery relocation with second battery | onewinner | 5.0 Mustangs | 1 | May 30th, 2007 11:30 AM |
| Battery | Mustang Mike | 99-04 | 2 | February 27th, 2007 07:07 PM |
