Anybody gone from 2.73 to 4.10? - Forums at Modded Mustangs
post #1 of 20 Old March 28th, 2009, 10:48 PM Thread Starter
I Was wondering who on here have changed from 2.73 to 4.10 gears and how much of a change in acceleration and over all improvements. My car is acually quite pitiful with 2.73s. Anybod use 3.90s here? Thoughts??
1987 Mustang GT 5.0 5spd t-roofs, FRPP 4.10 gears, MM subframe connectors, FRPP a arms, Tokico Hp struts/shocks, alum rad, electric fan, dcc fan control unit, 6g alternator
Ntv69 is offline
post #2 of 20 Old March 28th, 2009, 10:56 PM
baine21225's Avatar
search
baine21225 is offline
post #3 of 20 Old March 28th, 2009, 10:59 PM Thread Starter
Originally Posted by baine21225 View Post
search
thanx,good answer, read every gear thread here
Ntv69 is offline
post #4 of 20 Old March 28th, 2009, 11:03 PM
baine21225's Avatar
then that should answer your question
post #5 of 20 Old March 28th, 2009, 11:11 PM Thread Starter
Seen lots about upgrading from 3.27 etc, NOTHING about 2.73 to 4.10, what your problem anyhow.
Ntv69 is offline
post #6 of 20 Old March 28th, 2009, 11:14 PM
baine21225's Avatar
no problem, you just must not know how to search or read......if you have an auto go 4.10 if you have a manual go 3.73, it will make a huge difference, best bang for the buck, no need to be an asshole
post #7 of 20 Old March 28th, 2009, 11:17 PM
baine21225's Avatar
simple search for "410"
Forums at Modded Mustangs - Search Results
post #8 of 20 Old March 28th, 2009, 11:21 PM Thread Starter
Not meaning to argue or be an asshole, spend alot of time reading, and half of its wasted reading retarded responses for some peeple to get a higher post count. I Do have a t5, and have seen alot of people saying 4.10 instead of 3.73, for a car not driven on the highway that much, street driven. There is not a whole lot of responses about how much better they liked or not, how much better it accelerated etc.
Ntv69 is offline
post #9 of 20 Old March 28th, 2009, 11:26 PM
baine21225's Avatar
much better
post #10 of 20 Old March 28th, 2009, 11:38 PM
4.10s are fine for the highway.
don't fear the gear.
R0B0T is offline
post #11 of 20 Old March 28th, 2009, 11:51 PM
nolife's Avatar
You are not going to get meaningful comparison numbers from anyone unless they have run both 3.73 and 4.10 in the same car and they have some numbers for each and your combination is similar to theirs. Everything else will be an opinion on why someone chose one or the other.
nolife is offline
post #12 of 20 Old March 29th, 2009, 12:13 AM
QTRHORSE's Avatar
I have run 373 & 410 in the same car and also 390s! I ran out of gear in 4th with a t-5 before I crossed the line with 390s and 410s! But that was on nitrous! My opinion is if your gonna run a blower or N2O in the future go 3.73 with a manual! I currently run a 3.55 with a C-4 auto and a 150 shot and still pull 1.70 60ft & it goes 11.60@114! All stock suspension on et streets at 3500 pounds
CRT-Performance Tuned by Jeff Chambers in Norwalk Ohio, 2.6 Kenne Bell, 62mm T-Body, LT Headers, O/R H-pipe, 4.10s, Foxlake CNC Heads, VSR Stage 2 cams
530/447 Mustang Dyno www.crt-performance.com
QTRHORSE is offline
post #13 of 20 Old March 29th, 2009, 01:06 AM
Sheriff Metal Face
Chris951's Avatar
I have 4.10's. Only thing I don't like about them is shifting every .7 seconds during normal city driving.
Chris951 is offline
post #14 of 20 Old March 29th, 2009, 01:12 AM
that's funny...
i trap 112-113 with 4.30 gears and 28" tall tire(same as 4.10s with 26" tall tire) on spray.
granted, i have to rev the car to 6k and the stock cam doesn't like it too much, but it's not that bad.
less gear would help, but i'm not "running out of gear", so much as running out of cam...
R0B0T is offline
post #15 of 20 Old March 29th, 2009, 01:41 AM Thread Starter
Isnt that the fun part, lol
Ntv69 is offline
post #16 of 20 Old March 29th, 2009, 01:43 AM Thread Starter
What tires you running?
Ntv69 is offline
post #17 of 20 Old March 29th, 2009, 02:03 AM
Sheriff Metal Face
Chris951's Avatar
225/60/15. And no it's not very fun lol. I miss my old fox with 3.27's lol
Chris951 is offline
post #18 of 20 Old March 29th, 2009, 07:49 AM
408gt91's Avatar
Auto = 4.10 Stick = 3.73 4.10's suck on the highway if you're going to travel with your car. I have had them both and i perfer 3.73 in my gt.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
408gt91 is offline
post #19 of 20 Old March 29th, 2009, 09:32 AM
M L Struck's Avatar
+1
and 1st gear is worthless it's like a granny gear, the fun only lasts about 10 minutes. 3.73's
M L Struck is offline
post #20 of 20 Old March 29th, 2009, 10:35 AM
1slo5.0's Avatar
There will be a major change in accleration because you are making a major gear change. Acceleration goes up, fuel economy goes down.
1slo5.0 is offline
Human Verification
