Discussing b303 cam with 1.72rr's in the 5.0 Mustangs Forum. Is it safe to run this combination on a set of explorer gt40 heads? Not ...
Old January 16th, 2007, 03:57 PM   #1
Is it safe to run this combination on a set of explorer gt40 heads? Not the p heads. When i installed them they seem to compress the spring almost all the way. Is this normal?
Old January 16th, 2007, 04:52 PM   #2
With stock springs? What's the specs on that cam?
Old January 16th, 2007, 05:24 PM   #3
Yes the springs are stock. I believe the lift on the cam is around .480
Old January 16th, 2007, 05:29 PM   #4
Just checked and the lift is .480 and the duration is 284.
Old January 16th, 2007, 05:57 PM   #5
I don't think you're maxing the springs at .480 lift but I would change the springs out if you put a new cam in anyway. . .
Old January 16th, 2007, 06:36 PM   #6
lineumup88's Avatar
i agree. when you put in a new cam the spring should be changed. when you run a certain duration on the srpings for any period of time. the spings become acustomed to that compression. when you change cams you changed the stress point on the spring which cause which cause the spring to heat on diffrent places. it could or could not effect performance,
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Threads Similar to: b303 cam with 1.72rr's
B303 Cam acmillr 5.0 Mustangs 32 November 9th, 2007 09:10 PM
B303 or E303?? 92mustanglx 5.0 Mustangs 13 May 29th, 2007 06:38 PM
B303 cam homebrewed 5.0 Mustangs 21 March 9th, 2007 12:07 AM
