Proud American
351W with C4
anybody know what it takes to mount a C4? and also does anybody have the measurement for how long the driveshaft will be?
its the same bolt pattern as a 302 so its gonna bolt right up. driveshaft should be the same length as the stock one. (not 100% sure)
Proud American
I guess i should of said crossmember... I have a bell housing (157 tooth, the small one) but where the C4 mounts to the chassis. And I hope stock length works, if not ill get a custom aluminum one.
#4 | |
On a fox body you just need to grind off the tack welds on the crossmember tubes and slide the crossmember all the way forward on the tubes. Then reweld it. I'm not sure on a 94 and newer. It isn't real hard to make a custom crossmember and it will be much stronger than the stocker.
Proud American
Darrell do you know if im going to need a different yoke? I had a T-45 before, and I know that the AODs had a different yoke, but i took my buddies T-5 93 fox body driveshaft and it slid on the tail shaft and fit in my tranny just fine.
Also ill look at my cross member, and ill post a picture if I have a question. thanks!
#6 | |
96 and up stangs have a dif length drive shaft
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
#8 | |
Proud American
And maybe somebody could measure the length of a Fox driveshaft for me, or a 94/95 driveshaft. And then I could get mine cut... or I can get my aluminum one I have cut and rebalanced... BTW I have not looked at the Crossmember from my car. I went and put my buddies T5 back in and put in a new fuel pump for him and helped him put new fuel rails on his 93 last night instead...
Threads Similar to: 351W with C4
| 351w | shadowgames81 | 5.0 Mustangs | 31 | January 29th, 2009 07:02 PM |
| 351w | notsoslow50 | 5.0 Mustangs | 9 | October 8th, 2007 07:22 PM |
| 351W | stang94 | 94-95 | 1 | May 10th, 2007 02:38 PM |
| 351w | dragpipe | General Tech | 2 | May 2nd, 2007 08:53 AM |
| 351w | terribleonexx88 | 5.0 Mustangs | 11 | December 31st, 2006 02:08 PM |
