help needed
my 88 gt started running rough a few weeks ago, it runs like crap for a few seconds then clears up, it does this every minute or two and has gotten increasingly worse with time mainly when you get into the throttle some. so i unplugged the tps and it made it stop running rough, replaced tps still does it, unplug new tps and it clears up the rough shit again it just has the normal loss of power from having the tps unplugged but no running like shit then clearing up.
i tried unplugging the iac and starting the car and it wont run without the iac plugged in, ive fully cleaned the iac now and plugged it back in. ok so i have my tps plugged back in and unplugged the vacuum line to my fuel pressure regulator and it makes my car run properly, so i take it my FPR is bad.... any input is apreciated, sorry for all the backround im just hoping someone has had this issue before and can tell me what to replace next....
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears '93 LX 4-banger 78k miles Last edited by kuskye25; April 2nd, 2009 at 11:05 PM. |
i would look at the injectors, but i use to be a chevy guy, and i'm on my first stang. but it wouldn't hurt to tast them. they have known issues with cold start/ rough idle.
i probly wrong but it couldn't hirt. |
#3 | |
sorry i forgot to mention its fine till it warms up. if i leave the fpr unplugged its fine period...
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears '93 LX 4-banger 78k miles |
fuel pressure at the rail
Key On Engine Off 35 - 45 psi Key On Engine Running 30 - 40 psi Typical Fuel Pressure Regulator PURPOSE The fuel pressure regulator controls fuel pressure supplied to the injectors. The regulator also traps fuel during engine shutdown, thus eliminating the possibility of vapor formation in the fuel line, and provides instant restarts and initial idle speed. OPERATION Balancing one side of the diaphragm with manifold vacuum maintains a constant fuel pressure drop across the injectors. Fuel in excess of that used by the engine is bypassed through the regulator and returns to the fuel tank. CONSTRUCTION The regulator is a spring loaded diaphragm operated relief valve. One side of the diaphragm senses fuel pressure and the other side is connected to intake manifold vacuum. |
i haven't had the problems with my 87 yet, but i am having many other problems, so i've been doing alot of research on stangs and i'm mentioning issues that i've read on. i wish i know for sure, but just read up on know issues.
#6 | |
im not really sure what you mean by this but do you think it is my fpr
what your describing fits 84-90 mustand 5.0's but i can't find much on 93.
Hard cold starts, hesitation and stalls on initial start-up or during idle or decel may be caused by sludge in the throttle body and/or idle by-pass valve. Sludge deposits or oil film on the throttle body bore and plate or the idle air by-pass valve may cause one or more of the following conditions. ^ Hard Cold Start ^ Stall On Initial Start-Up ^ Stall During Idle ^ Stall During Decel ^ Rough Idle ^ Rolling Idle ^ Hesitation During Acceleration ACTION: A new idle air by-pass service kit (F2PZ-9F939-A) is now available for service use to correct sludge contamination concerns of the throttle bore and plate only. It eliminates the need to clean the majority of past model throttle body applications. Cleaning is not required on sludge tolerant throttle body designs released for 1991 and newer model years |
#9 | |
the more i look i think ill replace my fpr and do a base idle reset i think...
i would check the fuel pressure to make sure it's not that, and then the ohmz reading on the injectors to make sure they all read roughly the same to make sure ones not bad.
update this thread when you find the problem so i'll know for future needs.
good luck |
i have no resourses and little knowledge in that area, so can i buy something cheap to check the fuel pressure, and what should the injectors be at, thanks
yeah im just hoping someone will come along that has had this issue, i know its something basic and simple, if not ill figure it out eventually, all my gt does is collect dust anyway... haha
not sure about the feul pressure, just repeating what i read. and the resistance on the injectors should be between 11-18 Ohms. whatever they are, they should all be roughly the same number, if one is way off, then you have a bad one.
i'm open to any other suggestions on the problem. |
i agree, i'm sure it's something simple too. i wsh iknew what it is so i could tell ya.
#17 | |
Did you check for codes?
#18 | |
1993 5.ohhhh
12.97 @140mph
93 hatch has a good how to on pulling up codes for obd1 cars. Do the search my good man.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
Threads Similar to: help needed
| i know i know... but help is needed | samuel642000 | 5.0 Mustangs | 10 | January 31st, 2009 01:30 PM |
| what all is needed?? | Iownastang | 5.0 Mustangs | 6 | October 24th, 2007 01:44 AM |
| HELP needed in NJ | jersey98gt | Northeast | 3 | August 21st, 2007 05:54 PM |
| Help Needed | XxMUSTANGxX | V6 Mustangs | 34 | February 19th, 2007 10:13 PM |
| What's needed?? | 2ndChildhood | 94-95 | 3 | December 3rd, 2006 11:49 PM |
