How do you pull the pulley off the power steering pump? - Forums at Modded Mustangs
post #1 of 8 Old April 4th, 2009, 07:28 PM Thread Starter
Is there a nut inside the shaft holding the pulley on? doesnt really look like it, unless its a fuckin torx head, and once i get a puller and get the pulley off, how do i get it on the new pump?
93hatch is offline
post #2 of 8 Old April 4th, 2009, 08:03 PM
shadowgames81's Avatar
I do know they make a special pulley puller for it cuz I just did it the other day but I can't remember about a nut or anything. I want to say it was just pressed on so you'll need a way to press it back on.
Eats rice daily
shadowgames81 is offline
post #3 of 8 Old April 4th, 2009, 09:43 PM Thread Starter
but hooooooooooooooooooooooow do i press it back on??
93hatch is offline
post #4 of 8 Old April 4th, 2009, 10:40 PM
Nice 5.0's Avatar
There should be threads in the middle of the shaft. If you find out the thread size you can get a bolt and thread it in there. Use a nut and washer to push the pulley back on.
Nice 5.0 is offline
post #5 of 8 Old April 4th, 2009, 11:40 PM
TN.Frank's Avatar
You can rent a power steering pulley puller at the "Zone". Or they'll probably let you use it there for free if you take in your old pump to pull it. I've done it a few times and it's not that hard with the right tool.
TN.Frank is offline
post #6 of 8 Old April 5th, 2009, 12:19 AM Thread Starter
ohhhhhhh i gotcha, like hold it with the puller and screw a bolt in there? or idk how youd do it without the shaft spinning
i gotcha, is there a nut in the middle? and howd you get the pulley on the new pump?
93hatch is offline
post #7 of 8 Old April 5th, 2009, 09:23 AM
TN.Frank's Avatar
There's a tool in the kit that screws into the power steering pump shaft(not that hard, the shaft won't turn on ya.) then you tighten down a nut that pushes the pulley onto the shaft while holding the bolt that you screwed into the power steering shaft with a wrench. Just take it into any of your local AutoZones and they'll put the pulley on for you free of charge, at least we do that for customers here in Crossville all the time.
TN.Frank is offline
post #8 of 8 Old April 5th, 2009, 03:10 PM Thread Starter
so it is threaded inside! thanks dude reps
93hatch is offline
Human Verification
