Car keeps blowing fuses - Page 2
Old April 7th, 2009, 01:48 PM   #21
Stangzilla's Avatar
Stangzilla is on a distinguished road
Originally Posted by 93hatch View Post
hmmmm my cars name is krystal, so youre saying krystal might be a dyke????
You would not happen 2 live in a trailer or near a trailer park do u? I only ask cuz I have never known a girl named Krystal that did not live in a TP or was some sort of... well u know..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old April 7th, 2009, 01:53 PM   #22
1992 Lx
11.39@119.24
noooooooooooooooo girls named krystal are hawt, girls named Crystal are the ugly ones
Old April 7th, 2009, 01:59 PM   #23
Skirt Chasing Philanderer
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
I can say from personal expierence that you are incorrect... There were two Krystals in HS and one Crystal and they were all uglier than shit.
Might want to consider writing down what is said above, it will help you at some point or another in your life!
Old April 7th, 2009, 02:07 PM   #24
Stangzilla's Avatar
LOL!! I knew I nailed that 1?!!! lol....
Old April 7th, 2009, 02:07 PM   #25
1992 Lx
11.39@119.24
take that back! well my gf's name is shinri so i wont argue nomo
Old April 7th, 2009, 02:09 PM   #26
Stangzilla's Avatar
K well I'll leave that one alone. She is your woman I wont dispespect....
Old April 7th, 2009, 02:20 PM   #27
1FastFox's Avatar
Nike Fast
+1
BTW- Hatch, I agree with project about the autometer dimmer box, just get it and save yourself alot of hassel down the road ( and it will pay for itself since your blowing through money on fuses ).
Old April 7th, 2009, 02:27 PM   #28
baine21225's Avatar
unhook your gauge wiring and see if everything works alright, then if it does you know its something you did. i forgot that you are running an electric temp gauge, are you running the power wire to the dimmer, if so you should not be? they do have a power wire yes? and also a positive and negative for the light? if so then hook the power wire for the light to the dimmer switch and make sure the ground you have is good (sand down the metal to get good contact on both spots) and put the power wire for the actual gauge to the radio fuse. you wont need more than like a one or two amp fuse for the light, and im not sure about the other power wire......assuming you have one
"Whip out your dick you'll either get it sucked or get smacked..."
Old April 7th, 2009, 03:20 PM   #29
1992 Lx
11.39@119.24
im running the gauges power from the radio fuse (i dont even have a radio) its just the light i had going to fuse number 13, the grounds are good idk why its blowing fuses?
Old April 7th, 2009, 04:00 PM   #30
91Project's Avatar
1991 Mustang GT
91Project is on a distinguished road
I never did figure it out as to why it was blowing up my dimmer switches ( and fuses because of it ), but I havent had an issue once I got that autometer box ( which has been awhile ). I was like you though, cut power into the radio power ( with no radio ) and the ground to a good ground, and the other wire to my dimmer switch for lighting control.
AutoMeter C2 Nitrous Guage FS PM for details
Old April 14th, 2009, 01:20 PM   #31
91Project's Avatar
1991 Mustang GT
soooo... get it fixed?
Old April 14th, 2009, 01:47 PM   #32
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
I don't agree with that at all. He is blowing fuses more than likely because the gauge is wired improperly so if that's the case than why put a band aid on the problem instead of fixing the problem? I see way to many people band aiding problems these days instead of diagnosing and fixing the problem. But then again that has not been determined as the issue so if that isn't the issue than buying the dimmer box would be a waste of money. Find the problem, fix the problem and then buy a dimmer box if you think the factory dimmer switch isn't cool enough to do the job.
Old April 14th, 2009, 01:51 PM   #33
1992 Lx
11.39@119.24
i dont think i wired it wrong, its 2 wires
and 91project i just kinda gave up and unplugged the light in my pod, i could see how if it grounding out against the body it would make it blow fuses, but depending on which fuse blows, the pod will stay on but the dash lights wont so idk, just got frustrated and said fuck it for now
Old April 14th, 2009, 02:10 PM   #34
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Obviously it is wired wrong if it is blowing fuses and since you've unplugged it the fuse blowing has stopped. Either that or there is a short in the wires or gauge. It doesn't matter if there is 2 wires or 222 wires, it can be wired wrong. It could be that you have it spliced into a slot that is not designed to handle the extra load, hence the 5 amp fuse. The fuse is sized according to the wiring. If you put a bigger fuse in so it doesn't blow, guess what is going to happen next....
Old April 14th, 2009, 03:51 PM   #35
91Project's Avatar
1991 Mustang GT
I know what hes saying about not being able to wire up two wires wrong... When I mentioned the dimmer box it wasnt suppose to be a bandaid, its suppose to be the proper way to do it. The dimmer switch cants handle these guages being wired into them, hence why it keeps frying them. Hatch, Im 99% certain its your dimmer switch. Swap that out ( $5 off ebay ) and wire everything into the autometer dimmer box and you wont have to worry about running into this agian...
Old April 14th, 2009, 04:35 PM   #36
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I agree with this. Placing a 15A fuse in a holder that came with a 5A fuse is straight up DUMB!!! Unless of course you're trying to catch your car on fire and then you're on the right track.
You said that when you put a 5A fuse in (like you should have), it blows when you turn the lights on. This should indicate to you that you have added to much load to the circuit. This is not a reason to increase the fuse size, it's a reason to find a different circuit to hook things up. You should NEVER increase the fise size as they are determined by the wire size. Increase the fuse rating and you can melt the wires and catch your car on fire.
Old April 14th, 2009, 04:40 PM   #37
91Project's Avatar
1991 Mustang GT
I agree and would have mentioned it earlier but I just assumed this was unsaid common knowledge... This isnt a hillbilly forum for trucks where someone has their radio, four KC lights, CB Radio, and beer cooler all ran off thier cig lighter.
Old April 14th, 2009, 04:40 PM   #38
1992 Lx
11.39@119.24
sooooooooo i just need a new fuse to tap into to get power to this stupid lil light?
Old April 14th, 2009, 04:43 PM   #39
Moderator
2003 Grand Cherokee
That's what I would do. The circuit w/ the cigarette lighter is a good one to tap into (especially if you don't use it). It takes a decent amount of current to heat up the lighter so the wire is big enough to handle it. If you don't use the lighter, you have more than enough room to run a few lights.
Old April 14th, 2009, 04:43 PM   #40
91Project's Avatar
1991 Mustang GT
No you need to replace your dimmer switch, THEN replace the fuse, and finally wire your guage up to something else ( or the dimmer box listed above if you wish to controll the brightness )...
EDIT: the "No" was directed at 93 not 03...
Threads Similar to: Car keeps blowing fuses
fuses jasons_98gt 96-98 3 January 7th, 2009 05:23 PM
Keep blowing fuses Chris951 5.0 Mustangs 11 December 7th, 2008 01:35 PM
fuses? supercharged03gt 99-04 12 January 30th, 2008 01:25 PM
fuses...... rioswimmer 5.0 Mustangs 4 August 13th, 2007 07:27 AM
Fuses sorrowfulkiller 96-98 3 June 14th, 2007 01:26 AM
