Car keeps blowing fuses
Old April 5th, 2009, 02:16 AM   #1
1992 Lx
11.39@119.24
Number 13 and number 4 specifically, 13 is where i tapped into for power to my gauge pod. If i put a 15a fuse in number 13, it blows number 4. I put a 5a in number 13 like im supposed to, it immediatly blows when i put my lights on. WTFN
Old April 5th, 2009, 02:50 AM   #2
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
And this all started after you hooked up your new gauge?
Old April 5th, 2009, 03:13 PM   #3
1992 Lx
11.39@119.24
like a week after outa knowhere
Old April 5th, 2009, 03:27 PM   #4
**Chris**'s Avatar
1989 LX Coupe
**Chris** is on a distinguished road
Disconnect the gauge and try a new fuse. Could be a short in the wire or inside the gauge itself if the fuse doesn't blow with the gauge disconnected.
http://img86.imageshack.us/img86/1241/notchbackskickass2zg0.jpg
7.87 @ 93 mph
Old April 5th, 2009, 03:41 PM   #5
1992 Lx
11.39@119.24
yeah fosho ill try that tonight when its dark so i could see it light up, still fuckin weird
Old April 5th, 2009, 04:14 PM   #6
fordtruckin89's Avatar
88 Hatch Gt/91 Lx Notch
N/A
fordtruckin89 is on a distinguished road
well since both are in direct relation to instrument cluster illumination and 4 blew when you put more amperage through 13 id say when you drilled something you might have exposed a wire to something, either way you have a short or direct ground on a positive somewhere in your panel, where did you mount this gauge at? what is the gauge for?
88 GT Hatch, BONE STOCK, Ponies!!! soon full length headers, x pipe, flowmaster 40's dumped before axle, pro 5.0 shifter, steeda clutch quadrant, centerforce clutch, 3.73 gears, keeeeeeep onnnnn dreeeeeeamin...
Old April 5th, 2009, 04:26 PM   #7
1992 Lx
11.39@119.24
its on the pillar, theres no wires behind it that i coulda drilled into, its a temp gauge and the gauge is working fine, just my cluster light and gauge light keep goin out
Old April 5th, 2009, 04:34 PM   #8
N/A
have you tried removing the lead and tryin a different source for power? maybe too much draw on the fuse circuit? its obviously something with panel lights though, anything else stop working? radio/courtesy lights? maybe the guage is grounding itself out, does it still work without the lights operating on it? im not an electrician but im just tryin to go through the steps and maybe help you out somehow...
Old April 5th, 2009, 04:37 PM   #9
1992 Lx
11.39@119.24
ohhhh gauge grounding out that could be it, im gona just run the fuses back to normal and pull my add a fuse out and see what happens, thanks
Old April 5th, 2009, 04:44 PM   #10
N/A
no prob, but if the gauge is grounding itself out it wont operate correct and will jump around and shit when fuse blows, or lights are turned on...good luck!
Old April 6th, 2009, 08:49 PM   #11
N/A
any luck?
Old April 6th, 2009, 09:55 PM   #12
91Project's Avatar
1991 Mustang GT
91Project is on a distinguished road
I has the same issue you did. Did you wire it into the dimmer switch and fried the switch, which kept blowing fuse after fuse when I was replacing them. I'm willing to bet I would say you probably did the same.
AutoMeter C2 Nitrous Guage FS PM for details
Old April 7th, 2009, 02:24 AM   #13
1992 Lx
11.39@119.24
any luck?
na just replaced them and unplugged my gauge light
got more specific directions???????
Old April 7th, 2009, 02:55 AM   #14
1992 Lx
11.39@119.24
oh wait i misread your question, i just used an addafuse to tap into the fuse for the dash lights
Old April 7th, 2009, 09:48 AM   #15
91Project's Avatar
1991 Mustang GT
Sorry I was drinking last night watching the game when I typed that out. I dont know for you specific situation as everyone wires everything different, therefore having lots of different outcomes to problem. I was messing with my problem for weeks trying to figure out what was wrong, finally I just got one of those circuited fuse jumpers from mac and pluged that fucker into the fuse whole and sure enough smoke started coming from my dimmer switch. Swapped it out and everything was fine for about 6 months till I smoke that one as well... Then I quit fucking around and just bought this :Auto Meter well worth the $20 to eliminate the hassel.
Old April 7th, 2009, 01:31 PM   #16
1992 Lx
11.39@119.24
gahhhhhhhhh im gona try another fuse to tap into first, i dont care if the lights on during the day if it stops blowing my fuses
Old April 7th, 2009, 01:35 PM   #17
Stangzilla's Avatar
Stangzilla is on a distinguished road
Sounds 2 me like your car is ?!! Get it? "Blowin Fuses" I kill me...!!
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old April 7th, 2009, 01:37 PM   #18
1992 Lx
11.39@119.24
hmmmm my cars name is krystal, so youre saying krystal might be a dyke????
Old April 7th, 2009, 01:47 PM   #19
Stangzilla's Avatar
Oh in that case she would just be your run of the mill whore!! Nuttin wrong with that..
Old April 7th, 2009, 01:48 PM   #20
1992 Lx
11.39@119.24
Threads Similar to: Car keeps blowing fuses
fuses jasons_98gt 96-98 3 January 7th, 2009 05:23 PM
Keep blowing fuses Chris951 5.0 Mustangs 11 December 7th, 2008 01:35 PM
fuses? supercharged03gt 99-04 12 January 30th, 2008 01:25 PM
fuses...... rioswimmer 5.0 Mustangs 4 August 13th, 2007 07:27 AM
Fuses sorrowfulkiller 96-98 3 June 14th, 2007 01:26 AM
