92 LX 5.0
Won't Start...
Well back to the forums after a year break, although this time I have a 92 5.0 instead of an 02 GT... The problem I have been having is the car has been stalling and will just crank once trying to restart... give it 5 minutes to sit or so and it fires right back up. This problems seems to have no set of conditions, it happens hot or cold, full/empty tank, any speed/ gear operation or just sitting at a light. I will be driving along and it just cuts out like someone turned the key off...I know these have problems with TFI modules, but it doesn't follow the typical symptoms... I am leaning towards fuel pump right now but haven't been able to check pressure... I am taking the car to the shop tomorrow, to continue troubleshooting. Thanks in advance guys and gals.
12.9 @ 105
IAC motor. When you try to restart it do you give it any gas. Try giving it maybe half throttle when it wont start. If that causes it to start then i would learn towards the IAC motor. You can actually take the IAC motor apart while your testing and manually operate the plunger and see if it will start that way.
1988 lx
13.13@101.78
hows it run?
![]() 302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's |
92 LX 5.0
When trying to restart I have tried half throttle and full throttle. Right now all it does is crank... Do you think that could cause the random stall though?
92 LX 5.0
And once its running it runs strong... not sputtering and a smooth idle.
1991 mustang 5.0
Check your fuel pressure. If it was the TFI, the engine wouldn't start at all but it would crank. So I don't think that's your problem. Replace the fuel filter and see if that does anything.
92 LX 5.0
Yea it was about a once a week issue but now it doesn't start at all. I did replace the fuel filter about a month ago once the symptoms started.. The car didn't have any problems for a couple weeks, then it came back. I have been trying different things each time it cuts out. Banging on fuel tank, working the car back and forward while in gear... ect.
92 LX 5.0
bump for a little love...
12.9 @ 105
You gotta start with the basics. Check for spark and fuel when it won't start. Also check the fuel injector harness. And see if it has a pulse. Sounds like it may be a computer but you need to do some troubleshooting.
1989 LX Coupe
7.1@99mph
x2 on the computer.
But check your fuel pressure too. Fuel pumps can also be 'weak' and cause havoc like this. |
Threads Similar to: Won't Start...
| no start | 90mustang50 | 5.0 Mustangs | 3 | July 18th, 2008 02:50 PM |
| Start up | chris1 | 4V / SVT | 15 | July 15th, 2008 11:05 PM |
| where to start | EasyE64 | V6 Mustangs | 63 | September 25th, 2007 02:50 AM |
| i like the start | DanishStallion | Videos | 2 | March 22nd, 2007 09:05 PM |
| Where to start | mikedoogen | 2005 - 2010 | 17 | March 20th, 2007 09:19 AM |
