Discussing Rich and lean at the same time? in the 5.0 Mustangs Forum. well, when I'm at idle my A/F ratio is about 16:1, not ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
well, when I'm at idle my A/F ratio is about 16:1, not too horrible for idle....but a lean mixture nonetheless however; its spews gas out of the tail pipe? not like dumping, but after a min or two you can start to see the moisture, this does not make sense to me? Any ideas?
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
Condensation ...........
"Velocity is better than over all air flow." PeteAndersonRacing.com |
1989 Mustang GT
14.70@99mph
combustion reaction:
fuel + air = heat + CO2 + H2O + harmfull other gases its most likely water...
- '89 Mustang GT - '90 Mustang LX |
1993 5.ohhhh
14.47 at 96 mph
My cars like 14.8 to 16.3 at idle... depending. Cruising anywere from high 13s upp until 17 were you let off the gas. You seem fine man.
Whats it doing at wot?
exploder top end with 12 psi of v-tech
91 LX
13.7@101
its common for water to come out of the tail pipe just from condensation
1993 5.ohhhh
14.47 at 96 mph
Did you end up getting a power pipe? My car ran into some cold weather today in fl. It's about mid 50s outside lol. 2nd gear pull did 12.3 and it normaly is in the 10.3 range. Had to stop that, to lean, but it pulled so damn hard.
i was thinking condensation as well buts it smell awfully like gas
don't really wanna push it that hard until after the 17th, then i'll drive it hard enough to break the next part.....i did get a powerpipe, ended up being like a 12 hr job, the guy i got it from didn't give me any of the rubber so i had to go track down a bunch of stuff to make it all work, then i had my msd mounted where the pipe goes out until i can get it over to the spot where my battery is (is going in the back soon) but naturally i didn't have enough wire to move it foreword a foot so i had to rewire the whole thing.....md weather is the most fucked up stuff you will ever see, it will be 75 one day then the next be high 30s so it's warm and cold i guess?
91 LX
13.7@101
yeah its like 35 here and snowing but 2 days ago it was sunny and 65.
Threads Similar to: Rich and lean at the same time?
| Car Running rich or lean?? | dgt_mustang | V6 Mustangs | 5 | November 28th, 2008 05:05 PM |
| miss,lean or rich? | 88stang | 5.0 Mustangs | 0 | July 17th, 2008 12:31 AM |
| spark plug lean or rich? | e3sean | 5.0 Mustangs | 9 | June 20th, 2008 10:33 AM |
| the A/F gon crazy (rich & lean) | mow | 2005+ | 10 | May 23rd, 2008 06:35 PM |
| Difference between running rich/lean | 1996gt | 96-98 | 3 | January 29th, 2007 04:30 PM |
