Atomized
Super complex problem Need some experts to help
Ok so i've had this problem with my car for over 6 months where it's like it has two modes. When it's cold or partialy warmed up it runs perfect. When it warm it runs like shit. Just ideling it will be intake backfireing, won't idle higher than like 600 rpm, with abrupt throttle changes it'll pop and surge and take off, While driving it runs fine but if i lift off the gas it'll just obnoxiously pop out the exhaust like an old dump truck or some shit. I thought it was cause I had a cam and was speed density so I converted to mass air and it didn't change a bit. I've tried 3 tps's, 2 coils,2 bap sensor, 1 map sensor, new wires, cap and rotor, new walboro fuel pump, used fpr that I bought from e3sean and i have a pretty new tfi. It seem like it would be timing but I've double and tripple checked it. There has to be something that can be affected by heat that can affect timing. The only thing I can think is my tfi. It's just weird cause it's almost like two modes in a comp or something cause some times i can turn the car off and restart it and it runs fine for couple of minutes but i now have a brand new a9l and mass air meter. I know it's not a problem with the conversion cause it's the same problem as before my car just idles right when it's running good cause of the conversion. I'm so lost guys please help I've been batteling this shit for 6 months. Maybe a coolant temp sensor, or cause i have a 160 tstat. Fuck i don't know
Open to closed loop.....run codes....look into the o2 sensors..
PeteAndersonRacing.com |
1991 Mustang GT
Checked your plugs recently? what do you have them gapped at?
AutoMeter C2 Nitrous Guage FS PM for details
Atomized
oh my god I've totally spaced my 02's how do you check codes on these cards. I've never done it cause I heard it works differently with speed density computers. Now I have the a9l. It's a nitrous car so I change my plugs all the time. There usualy gapped at .035
Here you go..... You will get two digit codes...will be easy to do....
Do the koeo test and the koer test(engine running) Report back
Atomized
i dont think the link showed
Atomized
ok sorry mustank new problem, My check engine light doesn't work since I converted to the a9l. I thought I saw a thread a while back on how you could use a analog voltage meater is this true?
Atomized
phhh sorry maybe I should read first huh. Thanks bro. Think the 02's could really make my car run that bad?
not to jack your thread, but mine has been doing the EXACT same thing recently! i was getting a code 91, which led back to my HEGO. computer is telling me O2 sensors as well...
Does your problem go away after you've been driving for a few minutes? once my 180 degree t-stat opens up it seems to stop the popping and power surges. let me know what your codes are and what you end up doing, i'm getting the same thing here and my fuel mileage has suffered from it as well.
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
coolant temp sensor for the computer. The one mounted in the black metal coolant tube.
Replace it.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Atomized
black metal coolant tube? Not the one on the lower mani?
1982 GT t-top
no proof of purchase
yes the black coolant tube for the heater hose
1992 Lx
11.39@119.24
i think thats what he meant
my coolant temp sensor is new...
![]() any other reasons why it would do that??
Threads Similar to: Super complex problem Need some experts to help
| Any Tv experts out there? | GTblackprodigy | The Clubhouse | 25 | December 5th, 2008 02:54 PM |
| Super Deal on Super CAI for S197 cars | Granatelli | Vendors | 48 | April 22nd, 2008 09:56 PM |
| Super Mobile Performance Problem | btrokc | 2005 - 2010 | 10 | February 1st, 2008 09:34 PM |
| HELP PLEASE YOU EXPERTS | sniperrider | 5.0 Mustangs | 21 | October 13th, 2007 10:57 PM |
| strange problem with guages - electrical experts? | 2kGT | 99-04 | 5 | October 10th, 2007 08:35 PM |
