fuel pressure issues.
Old April 7th, 2009, 09:57 PM   #1
1985 Mustang GT
viperlocc is on a distinguished road
so its a new holley 110gph mech. fuel pump. stock lines from the take to the pump, and bigger from the pump to the carb. clear filter right outside the tank which is full and clean (new filter inside). clear filter between the pump and carb which is full when i first start the car or let it sit for a while. empties out after it warms up and sputters fuel into it.
after its warmed up, i get between 3 and 5psi of pressure. when its first started cold its about 6.5 to 7psi. if i get on it a little bit, the pressure begins to fall to 3ish. The filter between the pump/carb is sputtering with fuel (not full, not even half).
all new lines (cept the stock in between the pump/tank).
am i getting low pressure because it may be to small of lines? i wouldnt think so seeing as its only a 110gph. i checked all the clamps and replaced most of the rubber lines to new fuel lines.
Old April 7th, 2009, 10:00 PM   #2
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
where is the pump mounted, middle of the tank or lower? Secondly, where is it drawing power from? If it has a hot wire running from the front of the car all the way to the back with no relay thats prob the problem.
Power loss over the resistance and length of the wire. If power is coming from the front of the car you have to run a relay to keep the volts at the pump up.
try wiring in a relay and see if that fixes it, im about 99% sure of it
Just a truck
Old April 7th, 2009, 10:07 PM   #3
1985 Mustang GT
mechanical pump which is bolted to the side of the engine
Old April 7th, 2009, 11:17 PM   #4
86er's Avatar
bad diaphram
Just a truck
Old April 8th, 2009, 12:15 AM   #5
1985 Mustang GT
bad diaphram...inside the pump?
Old April 8th, 2009, 12:25 AM   #6
86er's Avatar
the rod and the diaphram are all that are used to create fuel pressure, if the rod moves, the only other piece of the puzzle is the diaphram
Just a truck
Old April 8th, 2009, 08:29 PM   #7
1985 Mustang GT
but why would it give me full pressure when cold than warm?
only have about 50 miles on it, think jegs will take it back and give me a new one?
Old April 8th, 2009, 09:08 PM   #8
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
prob. not, unless it's under manufacturer waranty. even then... kind of iffy on used parts
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old April 8th, 2009, 09:28 PM   #9
1985 Mustang GT
well ill throw the stock one in and see what happens.
i just dont believe in the "even new stuff can be bad".
any way i can open it and see if its bad?
Old April 8th, 2009, 11:51 PM   #10
1987 ford mustang gt
well see when shes done
why dont you believe new stuff cant be bad? Things happen all the time..
347, torn apart again.
Old April 9th, 2009, 08:36 PM   #11
1985 Mustang GT
well i shouldnt say i dont believe in it, it just really hasnt happened to me in a very very long time.
Old April 9th, 2009, 08:47 PM   #12
86er's Avatar
should be a bunch of screws around the middle of it, take them out and it will split open.
hot and cold expansion, the rubber is prob pulled tight when its cold when it warms up the tiny hole or rip expands and becomes bigger
Careful when you pull it open, spring will want to go flying
Just a truck
Old April 9th, 2009, 09:46 PM   #13
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
If the diaphram is bad you should be losing fuel somewhere and if it isn't on the ground it's in the motor, pull the dip stick and see if it smells like gas.
Threads Similar to: fuel pressure issues.
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 12:41 PM
Fuel Injectors/fuel pressure 00silvergt 99-04 4 August 2nd, 2007 10:54 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 07:58 PM
fuel pressure issues Downtown02 99-04 17 May 23rd, 2007 02:52 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
