Chip Recommended
Old January 18th, 2007, 01:41 PM   #1
bigbadtalontsi is on a distinguished road
Chip Recommended
Should i get the computer chipped now that i have installed the new heads and intake? Mods are UDP's, BBk intake pipe, 73mm mafs,Gt40 heads,gt40 intake,bbk headers, full exhaust(no cats), and the enigine is a 308ci. I probably forgot a few. Also would this be a good time to upgrade the fuel pump. I have noticed the plugs are a little white, and i just replaced them a few days ago when i put the heads and intake on.
Old January 18th, 2007, 09:11 PM   #2
Stangzilla's Avatar
Stangzilla is on a distinguished road
Yes replace the pump with a 255lph pump....Right away!!
What size injectors are you running?
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old January 19th, 2007, 10:16 AM   #3
I'm running the factory injectors for the time being. I figured it was time to upgrade the pump. What about the chip? Is it kinda useless right now? Thanks for the input
Old January 19th, 2007, 12:41 PM   #4
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
A dyno tune is never useless. It may not be ness., right now. You could more than likely get bye w/ an uppgraded pump and adjustable reg for now. If you have any further plans as far as cam and what not than you might want to think about stepping up the injectors.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old January 19th, 2007, 02:11 PM   #5
Thats one mod i forgot. I'm running a b303 with 1.72rr's.
Old January 19th, 2007, 06:03 PM   #6
Stangzilla's Avatar
well since you are running stock injectors you will should at least go up to 24lb injectors with the mods that you have and dont forget you have to have the mass air calibrated for what ever size injectors you have. But for sure put a 255lph pump in the tank..
Old January 19th, 2007, 06:51 PM   #7
Where can i get the mass air flow sensor recalibrated?
Old January 19th, 2007, 07:43 PM   #8
95opal's Avatar
95 opalfrost gt
your using a C$L 73? just buy the sample tube for the correct injector.
5.0 magazines
Old January 19th, 2007, 10:57 PM   #9
I'm not sure if it is a C&L or not. It was on the car when i bought it. It measures 73mm on the side closest to the throttle body. With that being said what are my options?
Old January 19th, 2007, 11:03 PM   #10
Stangzilla's Avatar
If I were you I would get rid of that C&L crap and get a Pro-M, Granettelli or something like that. The C&L method of recalibrating by way of changing the tube is not as accurate as calbrating it The electronic way that other companys do. Reason being the changing of the air tube like C&l does has no way of knowing air denisty it only knows air flow by changing the air tube diameter. The other method is that is done electroniclly is able to measure the air density because the denser the air the more resistance it has therefore the cars computer is able to adjust the air fuel ratio accordingly. Thats one of the reasons why for example stand alone programmable management systems do not recommend C&L mass air sensors...
Threads Similar to: Chip Recommended
recommended shift rpm to learn david_beniuk V6 Mustangs 14 January 16th, 2008 09:43 PM
Recommended Mods -Need Advice Ashybear 5.0 Mustangs 8 May 31st, 2007 09:29 AM
Is an exhaust recommended if installing supercharger? silvel2edge 2005 - 2010 4 May 29th, 2007 09:02 AM
recommended tires ?? Invictus Modular Mustangs 13 December 15th, 2006 07:31 PM
Recommended exhaust for Mach 1? darkshadowshaker General Tech 4 June 30th, 2006 08:58 PM
