#21 | |
Don't buy the junk BBK intake for $570 when you can buy a used Explorer intake and throttle body for $250 and get the same or better performance. You don't need anything other than stock fuel rails because you aren't making enough horsepower to require larger fuel rails. You can erase the need for extra fuel line too. No need for a 75mm throttle body which might even cost you a few horsepower on such a mild combination. Use the 65mm Explorer throttle body with the Mustang linkage or just use the stock Mustang throttle body. The horsepower gains you will see from a throttle body will be minimal at best. When I say minimal I'm talking about 3 horsepower. I'd definitely look into a larger mass air meter though but I'd go with a PMAS over the Summit brand. Why do you need new injectors? Just because the outside plastic looks bad? The outside tells nothing about how the injector is working. But if you are going to buy new injectors, get a set of 24lb injectors so you have room to grow a little bit in the future. I'm willing to bet your stock 19lb injectors work fine. As for the heads, $600 is a fair price for rebuilt P heads. But if you look around you might be able to find a low mileage set that needs no major work for $250-$300. Before you do anything you need to find out why the car runs so bad. Most likely it is a simple problem that is ignition related or a bad sensor. The chances of the entire EFI system being bad is not likely at all. Chances are it will cost less to fix the problem than it will to convert to carb.
#22 |
1989 Mustang GT 5.0L H.O.
I"m sure the injectors are the original with 155K miles on em', I'd just like fresh ones to get me back to normal. I've read that 19# are more then enough for mild builds so I don't need 24# for what I'm going to do. Some guy tried to tell me that a stock 5.0L H.O. had a 65mm TB, I'm pretty sure I read that it's 55mm, who's right? With the better breathing GT40p heads I'd like to get a better intake and TB. So would the Cobra intake be ok or what. What about a 70mm TB and MAF, better or not. See, this is were FI totally confuses me. A good Edelbrock intake and 600cft carb is EASY, all the FI stuff is HARD for me to understand. That's why I'm ready to just give up and go Carb. I know I probably don't NEED billet Fuel Rails but I want them because they look a lot nicer then stock ones. I know that 75% of my problems are head related, 15% is probably the dizzy needing new parts and 10% is probably FI related with sensors and stuff being the main problem(O2's are probably oil soaked from the bad heads) so what do ya'll say I should do with this car. Better heads need a larger TB and MAF and a new Intake, right? Injectors and fuel rails would be nice since I'm in there anyway.
#23 | |
#24 |
darrell is exactly right. spend money on things you need. go through the whole car and make sure everything is clean, tight and functional. do smart upgrades that don't cost a lot of money. its not very hard to make a 5.0 nice if you spend your money wisely
Threads Similar to: tfi with carb need help
| How do i install a new TFI? | 93hatch | 5.0 Mustangs | 14 | January 13th, 2009 05:15 PM |
| TFI Trouble Shooting | TurboLX | Audio/Video | 1 | January 6th, 2008 12:32 AM |
| Car Dies While Driving (Help!) TFI? | bigred2k | 94-95 | 4 | August 24th, 2007 02:12 PM |
| TFI or EDIS | Quetzali1 | 5.0 Mustangs | 1 | August 9th, 2007 03:03 PM |
| carb ? | terribleonexx88 | 5.0 Mustangs | 11 | December 4th, 2006 01:21 AM |
