tfi with carb need help
i was wondering if you can run the tfi dist with a carb motor. i have msd box was just wondering if this could be done any help will be great. thanks
yes you can in fact that is what i used when i did my v8 bronco 2 tfi with a carb
If you are going to leave the computer in the car, why put a carb on it? Why not stay with EFI?
Authorized Vendor
![]() Join Date: Sep 2008
If you don't use a computer with the TFI distributor, its timing will be locked out. Depending on your plans, that may or may not be a good thing.
i dont have a computer i bought a 90 gt 5.0 and was just wondering if i could use the dist. that came with it.
Why do you want to put a carburetor on it????
meh
+1, finally someone who agrees with me. EFI>carb
But it looks as though he doesn't have the computer.. that's probably why he wants to go with a carb. Still.. I would find EFI stuff and set it back up. Definately worth it.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
1989 Mustang GT 5.0L H.O.
Why is everyone so Anti-Carb? EFI sucks ass, you can't tune it unless you've got a computer tech degree and if you don't have a lap top or other way to access your ECM you're pretty much stuck with what the factory puts into it. I LOVE carbs, I can re-jet em', adjust the air/fuel at idel mixture with a screw driver and there's no injectors or MAFs to worry about. Carbs are simple and for us Old School folks they work better then FI because we understand em'. I"m going carb on my '89. In fact I can't hardly wait. Of course I guess all you EFI guys like Auto Trans too so you can let the valve body do your shifting for you. I'd rather have the control then let some dang computer do it for me. Carbs and Manual Trans, that's the ticket.
![]() P.S. Here's the dizzy you want: Mallory 8555101C - Mallory 85 Series HEI Distributors No need for a computer and you can get the stupid coil off of the fender well to give your engine bay a cleaner look. Last edited by TN.Frank; April 11th, 2009 at 07:32 AM. |
#9 | |
1990 LX hatch
[QUOTE=TN.Frank;1987408]Why is everyone so Anti-Carb? EFI sucks ass, you can't tune it unless you've got a computer tech degree and if you don't have a lap top or other way to access your ECM you're pretty much stuck with what the factory puts into it. I LOVE carbs, I can re-jet em', adjust the air/fuel at idel mixture with a screw driver and there's no injectors or MAFs to worry about. Carbs are simple and for us Old School folks they work better then FI because we understand em'. I"m going carb on my '89. In fact I can't hardly wait. Of course I guess all you EFI guys like Auto Trans too so you can let the valve body do your shifting for you. I'd rather have the control then let some dang computer do it for me. Carbs and Manual Trans, that's the ticket.
![]() no, no, no. Carbs are subject to their own circuitry, which you cannot change. Yes you can re jet a carb, and adjust idle mixture, but ummm, thats it. if you have an extra 1 hour in your life and a internet connection, you can learn all you want about efi. Tuning is not too hard, yes you need a way to manage it, if you doubt it, just look up any of the top cars in any class and if allowed i'll bet most of them are EFI.
its not the fact i dont like efi actually i love it but i am working with a striped out drag car and i am using and old intake and carb i got to get it going it is going to be track only. just trying to get it going on a budget.
will that mallory dist. work with roller cam? thanks |
#12 | |
All I know is that a carb, intake and dizzy will run me about $700 bucks, to fix my EFI to the same level it'll cost about $1200. I can sit down and do things to a carb to make it run better, I'm pretty much helpless with EFI. One point did come up at work today, what about my Tach, it runs off of the TFI dizzy, right? When I change out dizzies and stuff will the Tach still work, can I hook it up to the new dizzy or will it be pretty much useless and I'll just have to buy a new Tach? I really hate to keep the EFI on my car, I hate the helpless feeling it gives me and I hate being a slave to sensors to make it work BUT if I'm going to have issues with wiring and stuff I may have no choice.
#14 | |
#15 | |
1990 LX hatch
Basically my FI is screwed. The car I have wasn't taken care of very well so I'll need ALL the EFI parts to get it back in some state of tune. I'm also getting the GT40p heads so I'll want a new intake and plenum which comes with fuel rails($570) new TB and MAF that'll be 75mm(TB+$126,EGR plate=$45 and MAF=$226) and the injectors look like toast, the plastic is looking real bad so there's a set of new injectors($168) add it all up and throw in $600 for the heads and I"m looking at about $1750 to do my top end. Of course that doesn't inclued a couple new O2 sensors, any high pressure fuel line that I'll need or any of the other little things like gaskets and stuff. I wish I'd never seen this car let alone traded for it.
#17 | |
1990 LX hatch
pretty close.
1990 LX hatch
Oh yea, linkage, air filter(new hood for air filter to fit under)
#19 | |
Summit SUM-227205 - Summit Racing Street & Strip® Mustang Throttle Bodies
Summit SUM-227505 - Summit Racing Street & Strip® EGR Plates for Mustangs Summit SUM-29050C-C - Summit® Mass Airflow Sensors Summit SUM-240019 - Summit® High-Flow Fuel Injectors BBK Performance 5001 - BBK SSI Performance Intake Manifolds Trick Flow Specialties TFS-51500600 - Trick Flow® Air Conditioning Eliminator Brackets Tri-State Cylinder Head - Chevy, Ford, Small Block, Performance, Aluminum Cylinder Heads You do the math and tell me where I'm wrong. Prices are going rate for most other places I've looked at if not just a bit cheaper. Car runs like shit, smokes, FI parts looks like shit. If I'm going to do it I"m going to do it right,not half assed so that means spending some cash on the set-up. Also, I'll have to totally referb my dizzy(new cap, rotor, TFI mod, coil, wires, plugs) just like I"m having to do the entire brake system, shocks, U-Joints, ect. The car I got is totally thrashed, it's going to take a lot of time and money to whip it into shape. Last edited by TN.Frank; April 11th, 2009 at 10:04 PM. |
Threads Similar to: tfi with carb need help
| How do i install a new TFI? | 93hatch | 5.0 Mustangs | 14 | January 13th, 2009 05:15 PM |
| TFI Trouble Shooting | TurboLX | Audio/Video | 1 | January 6th, 2008 12:32 AM |
| Car Dies While Driving (Help!) TFI? | bigred2k | 94-95 | 4 | August 24th, 2007 02:12 PM |
| TFI or EDIS | Quetzali1 | 5.0 Mustangs | 1 | August 9th, 2007 03:03 PM |
| carb ? | terribleonexx88 | 5.0 Mustangs | 11 | December 4th, 2006 01:21 AM |
