I need help with my motor...
Old April 9th, 2009, 11:48 AM   #1
1990 Mustang GT
Blkknght is on a distinguished road
I have a bone stock 5.0. I am thinking about doing a 331 stroker with GT40P heads, e303 cam, cobra upper and lower intakes, and full exhaust with 2.5 inch pipes......i guess im asking is there anything wrong with this set up? Im not looking to get myself in trouble with hp, just enough for when I need to see someones front bumper in my mirrors...
Old April 9th, 2009, 11:54 AM   #2
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
If you want to see the most out of the 331 stroker, id recommend rethinking your top-end. The gt40p heads and e303 cam will be holding you back.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old April 9th, 2009, 12:09 PM   #3
95StangMX's Avatar
95 Mustang GT
Yeah with that top end a stroker is going to be way choked down.....why a 331 and not 347 if you are going to do it? I would save the money on the rotating assembly and machine work and order you a top end kit from trick flow and then later down the road save up some money and do the stroker. Does the motor need to be bored now? is it running good? what is done to it....need more info....what do you have to spend?
Old April 9th, 2009, 12:13 PM   #4
1990 Mustang GT
the motor itself is bone stock, the only thing i have done to is thats not stock is the fuel injectors, they are from a 99 mustang....i wanted to do 331 instead of 347 just because i wanted more hp but not enough to get myself in trouble.....you guys have any suggestions on what i should do....id like to keep to somewhat of a budget....maybe 2000 - 2500
Old April 9th, 2009, 12:19 PM   #5
95StangMX's Avatar
95 Mustang GT
get a trickflow top end kit and call it done...Heads,Cam, and Intakes matched to work well together and about your price range and not near as much labor cost involved.....then when you are ready you have enough top end to keep up with a 347 rotating assembly and bore it .030 over.....you will pick up more HP with that top end than doing the stroker and those heads you listed
Old April 9th, 2009, 01:21 PM   #6
1990 Mustang GT
so your saying to use stock parts with the trickflow top end kit and cam is better than to do a 331 stroker with stock heads and cobra intakes?
Old April 9th, 2009, 02:30 PM   #7
89LX347's Avatar
89LX347 will become famous soon enough
for you, 331 and trick flow top end kit. end of story
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 9th, 2009, 02:36 PM   #8
I agree with whats been suggested... do the top end kit now and enjoy the 300hp and pickup a stock block or explorer motor and build up your stroker with that then swap the trickflow top end over and your done with minimal downtime
Old April 9th, 2009, 02:43 PM   #9
Bingo
PeteAndersonRacing.com
Old April 9th, 2009, 02:47 PM   #10
1990 Mustang GT
my stang has 158K miles, should i rebuild the block with the TEK?
Old April 9th, 2009, 02:52 PM   #11
Keep the stock block .............
Old April 9th, 2009, 02:54 PM   #12
1990 Mustang GT
yeah.....i wanted to do that, but i was wondering if i should replace the pistons and crank from just being tired or what not, which is why i was wanting to just do a 331 stroker.....
Old April 9th, 2009, 02:57 PM   #13
How do you know there tired???????? Rods never get tired...pistons dont get tired.... If need be just throw some rings and bearings at it.
Old April 9th, 2009, 02:58 PM   #14
95StangMX's Avatar
95 Mustang GT
When you have the heads off for the top end swap check the cylinders and see what kind of shape they are in. Does the car blow smoke or use a lot of oil? if not you are probably in good shape and dont need to bore the motor or do pistons or rings. You can always pull a compression test and see how it comes out and do a visual on the cylinders. Depending on how long before you do the stroker you could be fine, cause you will need to bore it when you do that. Or like someone else suggested get another block and build it and swap all of your parts. Or get a long block from FordStrokers.com 331-347-393-408-418-427 stroker kits and ford parts. and then put your trickflow top end on it. You have a lot of things needed when going to a stroker that you dont take into consideration.....TB, MAF, Injectors, Fuel pump, adj fuel pressure reg., etc it adds up very fast. You will be faster with that top end and no stroker than you would with the stroker and stock heads
Old April 9th, 2009, 02:59 PM   #15
1990 Mustang GT
well i dont, i just figured they would be after 158k miles.....at least the pistons right? wouldnt i want to get different pistons if i do a TEK? or no?
Old April 9th, 2009, 03:01 PM   #16
1990 Mustang GT
ok then, i do know that one or two valves are burning oil....plus my oil pan gasket leaks but other than that, it dont blow smoke.....
Old April 9th, 2009, 03:02 PM   #17
Why fix some thing thats not broke???????
158 k is just gettin broken in........
Old April 9th, 2009, 03:03 PM   #18
1990 Mustang GT
thats what i always thought, but some people have told me otherwise.....
Old April 9th, 2009, 03:04 PM   #19
95StangMX's Avatar
95 Mustang GT
"Some People" are idiots and dont know their ass from a hole in the ground.....Miles dont really mean a lot depends more on how the car was taken care of
Old April 9th, 2009, 03:05 PM   #20
1990 Mustang GT
so you think that if i were to put a TEK on, the rest of the block and internals would be able to keep up? How much HP gain are we talking about with this TEK anyways?
Threads Similar to: I need help with my motor...
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 09:34 PM
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
