1990 vert. gt
unknown@????
headlight problems : no low beam
One evening, I dropped a glass bottle in front of my fox in the driveway. While cleaning it up, I decided to turn on my 90 gt for the use of light, and having just gotten new pipes installed, I was in no real hurry to shut her off. While picking up the broken shards and listening to my fox growl, everything went dark. The idle was fine, radio was still playing, and the ambers were still on.I turned the high beams on and they worked fine,as well did the parking lights.I've since changed the bulbs, fuses,and even had the switch inspected for damage. So far the only thing Ive had success with is wasting money, I still have no low beams. Has anyone else experienced this sort of thing and if so what did you do to correct it. Its kind of annoying.
Headlight switch or the multifucntion switch and connectors are common problems. Bust out the volt meter or test light and some diagram and narrow it down.
Mustang FAQ - Engine Information
1989 Mustang GT 5.0L H.O.
After I took the dash out of my GT I didn't have any lights at all when I re-installed it. Found out that they're plugged into the turn signal switch, man, I felt stupid for not pluggin' em' back up. Anyway, you might check the turn signal switch too.
1990 vert. gt
unknown@????
okay!?
I tried the turn signal switch, that was fine. thing is they tested it with a meter at a local shop, it too was supposedly fine. I'm so lost at this point.
1990 vert. gt
unknown@????
oh, i guess no one else has had lighting issuse? If so HELP! I really need it on this one.
88 mustang GT
try to wiggle the turn signal switch around a bit and see if they flick on at all.
1990 vert. gt
unknown@????
thanks;but, I've tried that. I'm really at a loss for ideas here.
#8 | |
1990 vert. gt
unknown@????
cool
#9 | |
Yes that is the multifucntion switch but what do you mean it works fine? Did you test it for voltage for the low beams? Unless you did, you don't know that for sure because your low beams are not working. If you did get voltage for the low beams there, keep going working your way to the headlights until you find the problem. Keep in mind that those connectors and wiring pigtails get corroded over time and develop burns and bad connections. You may be able to find full wiring diagrams online somewhere like Autozone, Haynes or Chiltons manual, public library, or use the Tmoss link I already showed or someone else will post a link, but there is no other way to troubleshoot that unless you trace out the whole path with a test light, really.
1990 vert. gt
unknown@????
well, thanx. I will let you know of my progress, I appreciate your insight.
1992 Notch
was this issue ever resolved? i have the same problem
1993 Reef blue GT
I have just the opposite. Lows..no highs.
88 mustang GT
Garuntee it's the multi function switch(turn signal/hig-low beams) expensive to replace if you buy new. And if you have factory fogs, without the fog light fix, it's going to happen again. No doubt.
1993 Mustang GT
What is the fog light fix? I use my fogs all the time.
I have a 93 5.0 I love my car, and all my friends hate it. ![]() AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks |
88 mustang GT
i was going to post the link last night, but i was drunk, and on my iphone.
this not only saves your mulitfunction switch from melting and failing, but it lets you keep the fogs on without the headlights on, and they stay on with the high beams. Mustang GT Fog Light Fix
1987 Mustang GT 5.0
Well did you ever get the low beams to work? I had a similar issue when I purchased a 1987 Convertible Mustang GT except that all of the pigtails were melted together behind the headlight switch and dimmer panel switch so, non of the lights worked except the brake lights. So, I ended up doing the fog light fix, installing a new headlight fog light harness plus headlight switch pigtails, fog light pigtails, and dimmer panel pigtails. When I was done the only lights that did not work were the low beams.
So, after that I replaced the headlight fog light switch with no success. I ended up running a toggle switch that I purchased from radio shack. All I did was splice into the two red/black wires from the multifunction switch pigtails using T-Taps. Twisted the two wire ends together and then twisted them to the wire supply from the toggle switch. (Yes, I soldered and used heat shrink) Then I ran a wire directly from the batter positive terminal to a fuse holder and then to the toggle switch. Then I connected an earth wire from the 30 amp toggle switch to the frame. Reconnected the battery and the lights work. Last edited by 87GTConvertDavis; October 23rd, 2010 at 01:23 AM. |
#17 | |
88 mustang GT
1987 Mustang GT 5.0
The multifunction switch controls turn signal, high beam and wipers. The Headlight Fog light switch is to the left of the instrument cluster. The turn signal switch (control arm) is on the steering column. It's also called the multifunction switch. In my last post I said that I replaced it and the multifunction switch pigtails are not melted. Only the headlight fog light, dimmer panel switch wires and some of the wires behind the fuse box were melted when I made the repair and rebuild.
Threads Similar to: headlight problems : no low beam
| bi-xenon HID headlights- high/low beam question | LilPoni11 | Visual | 43 | January 8th, 2009 03:06 AM |
| Headlight Problems! Urgent! | WhtStang00 | V6 Mustangs | 11 | January 6th, 2009 11:41 PM |
| how do i get the headlight switch, high beam switch, emergency switch etc out? | 91cobra5.0 | 5.0 Mustangs | 0 | March 19th, 2008 10:39 PM |
| HID Dual Beam Headlight? | Kinshen | Audio/Video | 3 | January 12th, 2008 02:15 AM |
| HID Dual Beam Headlight? | Kinshen | Visual | 5 | January 5th, 2008 08:35 PM |
