cant figure out what to buy...
Old April 10th, 2009, 04:41 PM   #1
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
ok so i have about 270 to spend at latemodelresto.com and i can't decide what to get... im definetly buying the trickflow a/c delete and belt for about 60 and change and some new spark plug wires. but where im stuck at is between the steeda short throw shifter (Steeda Mustang Shifters at LRS - Same Day Shipping! ) or a set of upper and lower control arm w/ bushings (79-98 CONTROL ARM KIT, TUBULAR, REAR, UPPER & LOWER, BLACK MUSTANG ) im kinda leaning towards the control arms seeing as how i already have traction bars i think id be able to hook very well. thanks for any opinions guys.
shut up before i punch you in the throat
Old April 10th, 2009, 05:05 PM   #2
91 LX
13.7@101
control arms
Old April 10th, 2009, 05:05 PM   #3
What kind of shifter do you have now? I'd want the shifter with adjustable stops first so I have less chance of destroying the glass t5 trans even though the controls will help with wheel hope a bunch. I'd say both are a needed mod and you can't really lose eitherway
Old April 10th, 2009, 05:16 PM   #4
1993 Mustang
i have the stock shifter still. i know i need to upgrade both...
Old April 10th, 2009, 06:17 PM   #5
1993 Mustang
ok so i think i decided on the control arms for now lol but now im thinking of possibly scraping the wires idea and going w/ these 79-04 SUBFRAME CONNECTORS, RED MUSTANG . would these be good to install on a daily driver (for now) /occasional strip car?
Old April 10th, 2009, 08:33 PM   #6
90 GT
slow 98 is on a distinguished road
Yes do subframes, defently a good idea. the car will handle like its on rails.
Old April 10th, 2009, 08:42 PM   #7
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Yeah, +1 for the sub-frames and controll arm w/ bushings.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old April 10th, 2009, 08:44 PM   #8
November 08 ROTM
buddyantunez1's Avatar
2000 3.8L Mustang
195.9/220.8 hp/tq N/A
buddyantunez1 will become famous soon enoughbuddyantunez1 will become famous soon enough
Send a message via AIM to buddyantunez1
control arms first, then short throw.
~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~
Old April 10th, 2009, 10:30 PM   #9
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
Yeah definately go with the subframe connectors and control arms. After installing my subframe connectors and control arms, it felt as if I was driving a different car....You might look into a full length subframe connector, I would think they would be a little stronger than those standard length ones, but im sure the standard length ones would suit you fine.
BTW I got a set of full length subframe connectors from blue oval for like 100 bucks..
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old April 11th, 2009, 12:13 AM   #10
Do the subframes.. they should be one of the first mods for a fox iv'e seen stock foxes hook enough to cause stress cracks. With those subframes welded up and bolted to your seat bolts the car will feel more solided it sounds weird but when you hope and and drive it after the install you'll know what i mean.
Stock shifter is total junk but if the cable is adjust good it will work for a while but i'd rather invest in a nice shifter before damage to the trans occurs plus it's something you'll use allot were as the lower control arms will only really be used when launching but either one will work because both need to be addressed
Old April 11th, 2009, 11:59 AM   #11
1993 Mustang
ok so would you guys suggest waiting on the subframes till i can afford full length ones or will the standard length ones be good enough? yea i REALLY want to get a new shifter but i just can't afford it right now... its either the shifter or the control arms
Old April 11th, 2009, 12:07 PM   #12
86er's Avatar
make your own sub frame connectors
just buy some metal stock cut it and weld the bitches
Just a truck
Old April 11th, 2009, 12:09 PM   #13
1993 Mustang
easier said than done lol
Old April 11th, 2009, 12:29 PM   #14
86er's Avatar
not really, go buy metal stock, measure cut, and weld it to the car, it is as easy as it sounds
Just a truck
Old April 11th, 2009, 12:30 PM   #15
86er's Avatar
if you want to get fancy buy some small squares of metal and drill holes in them and mount under the seats and weld to the metal stock.
really not hard at all
Just a truck
Old April 11th, 2009, 03:55 PM   #16
Full lenght would obviously be better but not sure if there needed.. my turbo car which put done 460 and change on the dyno has the standard length t brace style subframes so it depends on what you want to do.
Old April 11th, 2009, 05:32 PM   #17
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
definitely get the full length..if u cant afford them now just wait a little bit
Cohagan Engineering, Inc.
Old April 11th, 2009, 08:02 PM   #18
1993 Mustang
i mean im not looking for an all out drag car... right now its a dd that i want to get into the 12s w/ maybe eventually the 11s
Old April 11th, 2009, 08:02 PM   #19
1993 Mustang
so would that be ok for the standard length connectors?
Old April 11th, 2009, 08:07 PM   #20
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
Originally Posted by grnstang View Post
control arms
i have no mustang. so don't listen to anything i say.
Threads Similar to: cant figure out what to buy...
cant figure it out notsoslow50 5.0 Mustangs 7 July 12th, 2007 09:25 PM
go figure! P.O.S-GT 5.0 Mustangs 3 June 22nd, 2007 10:13 AM
Figure this out... Foxstang90 5.0 Mustangs 3 February 18th, 2007 12:15 AM
Need Help... Cant Figure Out mustangrebuilder Classic Mustangs 5 September 6th, 2006 11:48 PM
cant figure it out ttop5.0 5.0 Mustangs 2 August 26th, 2006 06:54 PM
