1989 gt 347
whistle at idle??
hey gents, i have a high pitched whistle at anywhere from 800-1000 rpm. seems to be coming from throttle body or upper intake area. motor info in my garage. very annoying and loud. has anyone else delt with this??
Did the same on mine, and it was a a gasket, Mines also carbed though, Check the gaskets up under your TB.
1995 Nissan 240sx. Coilovers, intake, full 3in exhaust, RUCAS, J30vlsd, 1 piece drive shaft, Q45 Front brakes, short throw, subframe collar bushings. |
#3 | |
1990 LX hatch
Cheer up Charlie, dont be blue.... Its prolly a vaccum leak. For the "Golden ticket", spray carb cleaner around untill the idle picks up.
1989 gt 347
thanks for the replies, i have sprayed around everything in the area. i read in another post about there being a possible problem between having a larger throttle body than the opening for the intake. i'm not sure what the standard opening for the gt40 tubular intake is. does that sound possible?
BBK throttle body?
PeteAndersonRacing.com |
Bigger throttle bodies whistle.
Larger throttle bodies whistle. What is the "IAC restrictor gasket"? Hanging idle is caused by alot of things. Putting a band aid on the problem isn't going to fix it.
1990 LX hatch
Restricting the iac is just gonna make it take longer to make adjustments.
+1 on that. I run a 80mm tb and it whistles. No biggie.. I pretend i have a turbo!! lol..
1989 mustang gt vert
I am having same issue. I have taken it apart the whole lower upper intake twice. Never changed the whistle. I have a trickflow intake and summit 70mm throttle body and egr spacer. It is very annoying hope someone post a way to fix this. Just FYI for anyone with trickflow intake dont spray carb cleaner on it takes the paint off.
If you aint first ur last! |
1986 lx notch
9.98 @ 135
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
1990 LX hatch
whooo, whooooooooooooop!
#15 | |
1991 5.0 LX
That sounds like a good start to getting this fixed. I will be do this probally tomarrow and post results Thanks
1989 gt 347
the iac restrictor allows motor to return to idle faster from rev up, without hanging. i have ground all burrs i could find, as posted by ajhxxxiii, (thanks for the info by the way) but, still, same whistle. cburns, do you have an intake spacer on yours? maybe thats it, i dont know.
#19 | |
Threads Similar to: whistle at idle??
| Brake... whistle? | whtpny | 99-04 | 6 | February 13th, 2009 04:15 AM |
| whistle in engine bay | graystang01 | V6 Mustangs | 14 | November 12th, 2008 07:38 PM |
| Lope, Whine, or Whistle? | rk_2000_Z/28 | The Clubhouse | 26 | May 23rd, 2008 03:12 AM |
| Strange whistle in the front | Hawaiianbro | 99-04 | 14 | February 14th, 2008 03:14 PM |
| whistle tips | black04GT | Multimedia | 16 | August 21st, 2006 07:03 AM |
