Starter Shorting Out
Old April 12th, 2009, 06:43 PM   #1
91 gt 5.0 is on a distinguished road
The wire from my starter to the relay is grounding out. When it is connected to the post with the battery power wire on it, I get huge sparks when I go to connect the battery. The battery wire is brand new. The starter wire s brand new. Is this a bad starter, or what is wrong. I've tried two starters.
Old April 12th, 2009, 06:55 PM   #2
91 LX
13.7@101
look up a diagram and make sure all your wires are in their correct positions
Old April 13th, 2009, 10:37 AM   #3
I did that before I posted. There is only one place for the wire to go on the starter. From what I've looked at, on the solenoid the starter wire and battery wire are supposed to be on the same terminal.
Old April 13th, 2009, 10:55 AM   #4
89LX347's Avatar
89LX347 will become famous soon enough
some they go on the same sides, some they go on the opposite sides, try that.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 13th, 2009, 12:48 PM   #5
will do. Thanks for the suggestion.
Old April 13th, 2009, 04:20 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you put the starter cable and battery cable on the same terminal on the soleniold then it defeats the purpose of having a solenoid and the starter will continously turn over.
Old April 13th, 2009, 07:39 PM   #7
Thanks Darrell. That's what I thought but the two foxes I looked at were wired that way.
Old April 13th, 2009, 08:32 PM   #8
89LX347's Avatar
thats how mine is, but theres a little wire coming off my starter goin to the opposite side and the big red cable from my battery and starter are on the same side.
Old April 13th, 2009, 08:40 PM   #9
I'm pretty sure that you (89LX347) have a 93 style solenoid and probably a mini starter. IJust throwing that out there. 'm using the stock starter and solenoid (I believe). Both cars I looked at used the stock style starter and solenoid. I'm not working on the car until after class tomorrow, but I'm sure I'll figure it out. Thanks for the help guys.
Old April 13th, 2009, 10:56 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Then you must have the 92-93 starter set up with a solenoid on the starter and on the fender well.
Old April 14th, 2009, 12:02 AM   #11
89LX347's Avatar
thanks, ive always wondered how that worked
Threads Similar to: Starter Shorting Out
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
ignition coils shorting in water... WVSNS& 99-04 0 March 3rd, 2009 09:11 PM
Starter ? 00vabchgt 99-04 4 December 14th, 2008 06:57 PM
help with starter kuskye25 5.0 Mustangs 5 March 16th, 2008 11:07 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
