Throttle cable spring. - Page 3
Old April 20th, 2009, 12:43 PM   #41
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by flattusmaximus78 View Post
OK, so I put the stock tb on. The notch in my gas pedal is gone and the car drives so smooth. My idle still floats at 1200-1400 when in neutral while rolling and coming to stop. I hit the maf with a wrench while idling and it didn't do a thing. So I'm kinda stumped. I didn't set voltage on the tps to .98 but i dont see the point to be honest since it idles like the other tb that was set at .98.
I'm seriously stumped. I'm making good vacuum at idle so idk.
Also while I was under I noticed my fpr guage was reading around 30pi, but it was vibrating so much I couldn't get a good reading. Well I got it to stop vibrating. 30 PSIII wtf. Thats why i'm mid 12's at wot. Turned it up to 39psi and I'm at 10.0 wot again. So no boosting until I get my smaller pulley and a retune.
But is there anyway to switch the throttle stuff off my stock tb to my 76mm. I'm nervouse of dynoing and losing alot of power on the stock tb.
Switching parts to your other throttle body is not going help the problem. The reason why the pedal was stiff was due to airflow thru the throttle body. I bet the throttle body is smooth thru the entire travel now that it is off the car. Putting another big throttle body on is going to more than likely cause the same problem. I've seen it many times. It has to do with airflow and vacuum at little to know throttle opening. I don't know the exact reason behind it but I know it happens with big throttle bodies. I think it is probably related to cubic inches or airflow requirements of the engine. It seems that when I've experienced this issue it has been when the throttle body was too big for the application and over 75mm. I've run as big as 90mm on a 347 and that was smooth as silk but that engine made alot of horsepower.
Good lord i I didn't know my old tb was that pricey. There's no way to put the throttle parts off my stocker on the 76. New 70mm+ tb's are way to much.
If anyone has one I'll trade a pmas 80mm maf, and I have a bunch of stock parts lieing around I'll trade for.
Can you try that PMAS on your car? Does your chip have the injector size change accounted for? The factory mass air meter you have isn't calibrated for any injector. There is actually no relationship between the injectors and mass air meters. Aftermarket companies just use the mass air meters to fool the computer in order to run different injectors without a tune. If there was no correction added when you got your tune, that will be a problem. Also, check the TPS voltage. That can have an effect on idle.
Old April 20th, 2009, 12:57 PM   #42
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Well if what you say is true, I ran the 75 or 76 whatever mm it is with my 76mm c&l all motor for months. It drove smoothe as butter as far as the pedals concerned. As well as what you said it should have only gotten smoother since I eventually put the blower on and added an aditional 100 plus rwhhp. Or am I wrong with that concept? Either way the notchy pedal wasn't always there when I first got the blower on with the bigger tb... it drove pretty nice actually.
The pmas is for 30lb injectors and I have 42lbers in so thats a no go. And I know the tps voltage helps idle, but I didn't evne set voltage on the tps with the stock tps and it idles 100% the same way the bigger tb did when it was at .98 volts.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Threads Similar to: Throttle cable spring.
Throttle cable broken :( icon The Clubhouse 1 November 15th, 2008 05:02 PM
need help choosing throttle cable built351w 5.0 Mustangs 3 October 28th, 2008 09:54 PM
throttle cable db83stang 5.0 Mustangs 1 January 26th, 2008 02:39 AM
Throttle Cable Tightening dgt_mustang V6 Mustangs 7 November 10th, 2007 04:53 PM
