I need help PLZ!!
Old April 13th, 2009, 11:23 PM   #1
1992 Mustang lx
92 LX 5.0 is on a distinguished road
I need help PLZ!!
My 92 5.0 will bog spit and sputter at wot for a sec or so then will take off. My mods are fresh short block with E303, cam 97 explorer heads new springs and valves, 1.7 rr, Gt40 intake, 70 mm throttle body, 73 mm mass air cal for 24 lb inj, elec fan, underdrive pulleys, ford racing headers, off road xpipe, flowmasters and dumps, fresh trans with shift kit 2500 stall and 3.73 gears. timming set at 15 deg, tps 1 volt, 11 inches of vac at idle (seems to low to me but not sure idles very well). I have swapped a friends dist and coil which didn,t help. The car when stock with nothing but gears and flowmasters ran 9.4 to 9.5 in 1/8 with 2.15 60 ft times now best time has been 9.34 at 81 mph with 2.5 60 ft times no tire spin. If anyone has had this prob or has any ideas it would be very appreciated.
Troy
Pleasant View, TN
Old April 13th, 2009, 11:44 PM   #2
1986 mustang gt
1fst5.0 is on a distinguished road
u got an adjustable fuel pressure regulator?
Old April 13th, 2009, 11:46 PM   #3
88_FiveOh's Avatar
1988 lx
13.13@101.78
88_FiveOh is on a distinguished road
sounds like a fuel problem, check your fuel pressure and go from there
302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's
Old April 13th, 2009, 11:46 PM   #4
1992 Mustang lx
no
Old April 14th, 2009, 10:16 PM   #5
1992 Mustang lx
I have checked fuel psi, pressure good no drop. i have a new 110 gph pump
Old April 14th, 2009, 10:40 PM   #6
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i've had the same problem with my car, ended up being because of the O2 sensors, causing it not to switch back from rich to lean and kinda flooded the car out.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old April 14th, 2009, 11:00 PM   #7
1992 Mustang lx
did your car take off and run strong as hell after the bog and sputter
Old April 14th, 2009, 11:07 PM   #8
Traidmarx's Avatar
1995 Mustang GT
yea it would just sputter only while driving at cruising speeds however while it was sputtering i could push the clutch in and it would rev up without hesitiation. and i'd stomp it and either it'd bog down like i hadn't hit the gas yet, wait a few seconds and then take off...other times it'd just sputter until i held the gas down to the floor it sputter a few more seconds and then take off fine.
Old April 14th, 2009, 11:11 PM   #9
1992 Mustang lx
my car runs fine while cruising and under light throttle it only does it at wot man its driving me nuts because i want to see how all the new mods will make it run
Old April 14th, 2009, 11:13 PM   #10
Traidmarx's Avatar
1995 Mustang GT
have you checked the voltage on the tps??
Old April 14th, 2009, 11:14 PM   #11
1992 Mustang lx
yes i set it at 1 volt
Old April 14th, 2009, 11:18 PM   #12
Traidmarx's Avatar
1995 Mustang GT
hmmm yea it should read like .98 or so with the key in the on position....i'm thinking of what else it could be.
Old April 14th, 2009, 11:30 PM   #13
1992 Mustang lx
i keep thinking its probably somthing stupid im over looking
Old April 14th, 2009, 11:32 PM   #14
Traidmarx's Avatar
1995 Mustang GT
unless you've got some sorta vaccuum leak...which could be if there is air gettin in behind the MAF thats not accounted for until the MAF reads so much air going through due it being at WOT for a few seconds. that it balances itself out.
Old April 14th, 2009, 11:39 PM   #15
1992 Mustang lx
yeah i thought the same thing but i have checked for vac leaks haven't found any and the car idles very well vac is 11 inches at idle but im not sure what it should be for my e303 cam
Threads Similar to: I need help PLZ!!
help plz!! 1989Gt. 5.0 Mustangs 0 September 7th, 2008 12:04 AM
ok here goes.... plz help! Skinnywhiteguy223 96-98 5 June 18th, 2008 11:52 PM
Help plz!!! 1989Gt. 5.0 Mustangs 6 May 24th, 2008 07:25 PM
Help Plz! 707Stang The Clubhouse 4 April 1st, 2008 04:35 PM
help plz, trying to pull out the stock guage, asap plz 91cobra5.0 5.0 Mustangs 4 March 20th, 2008 05:51 PM
