'98 Explorer heads and intake.
Old April 14th, 2009, 10:36 AM   #1
TN.Frank's Avatar
1989 Mustang GT 5.0L H.O.
TN.Frank is on a distinguished road
I found a set of heads and intake off a '98 Explorer 5.0L, are these the GT40 heads and intake? If so I can pick em' up for $75 a head and $50 for the intake(guess that's intake and plenum) which would be a great deal even if I have to pay an extra $90 to get the heads re-worked. Don't have the casting numbers so I can't tell ya' anymore about em' then what I've already said. Talk to ya'll later.
Old April 14th, 2009, 11:04 AM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i think those will be the gt40p heads which is even better
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old April 14th, 2009, 11:16 AM   #3
TN.Frank's Avatar
Someone mentioned "issues" with the BBK shorty headers that I've got on the car. Another guy said to just run short plugs and 90 deg boots on the plug wires and I'd be ok. So, other then that will the headers bolt up with basically the same gaskets and stuff? If this swap will work then I'll save a TON of cash AND get the parts that I want. What about the TB on this intake, 65mm?, worth buying? or get an aftermarket one? Thanks, sorry for all the questions, I just want all my ducks in a row before I turn a wrench because I'll be under a time limit to get the car back on the road so I can get back and forth to work. Thanks.
Old April 14th, 2009, 11:23 AM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
The throttle body will require u to remove(grind) the spotweld holding the throttle shaft to the plate(where your cable goes on the bottom of the TB) it is joined to. do the same on your stock TB. put the one off your car on the xplorer TB, and spot weld it in place.
You'll have to cut and splice the TPS wires from the xplorer TPS to yours too. All said and done, I'd just buy a aftermarket TB.
Old April 14th, 2009, 12:08 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is an exceptional deal. 98 Explorers had GT40P heads. By the heads and intake. Have the heads resurfaced, get a valve job and toss in a new set of valve springs and they will be good to go.
Old April 14th, 2009, 01:30 PM   #6
1992 Lx
11.39@119.24
bbk shorties will work as long as theyre not equal length
Old April 14th, 2009, 03:55 PM   #7
TN.Frank's Avatar
And how do I tell if they're equal length? I'll get an aftermarket TB, will I need an EGR plate or not? I'm not nore will I ever run an EGR, hot air in an intake stream is just plain stupid,LOL. So what's it going to take to get the heads and intake hooked up to my Mustang 5.0L?
Old April 14th, 2009, 04:03 PM   #8
91Project's Avatar
1991 Mustang GT
91Project is on a distinguished road
Do the tubes on your headers look like they are all the same length? If so they would be equal lengths... You can tell shorties that are not equal lengths pretty easily.
AutoMeter C2 Nitrous Guage FS PM for details
Old April 14th, 2009, 04:11 PM   #9
1992 Lx
11.39@119.24
equal lenghts go all curley and shaped weird as fuck, un equal lenghts look basically like the stockers
Old April 14th, 2009, 04:11 PM   #10
TN.Frank's Avatar
I've never really gave em' a close look. I do know they've got a lot of dents in em', not sure why. So worse comes to worse I'll need a new set of headers to get these heads to work. Is that it? I'm getting a new TB and MAF and I'll also pick up a new IAC and TPS along with a couple new O2 sensors. I want all the sensors to be new so I'll not have any issues with em'. Will I need an EGR Plate to bolt the TB to the Explorer intake or will it fit as a direct bolt on? Thanks.
Ok, reading your post 93, the headers are "curley" so they must be equal length. So will I need unequals or will the equals work?
Old April 14th, 2009, 04:15 PM   #11
91Project's Avatar
1991 Mustang GT
My vote would be to just get some long tubes, but then your going to need a new midpipe and a few other odd bits...
Old April 14th, 2009, 04:24 PM   #12
1992 Lx
11.39@119.24
post a pic of the headers dude
Old April 14th, 2009, 04:54 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need an EGR plate or an EGR eliminator plate. The throttle linkage hooks to the EGR plate so you need one of the two so you can mount your throttle linkage. You will need about 4-8 hours to do the heads and intake swap depending on your level of experience.
Old April 14th, 2009, 04:54 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old April 14th, 2009, 05:02 PM   #15
TN.Frank's Avatar
Here's two pics of the driver's side header and one of the Passenger's side. On second look they may be non-equal length.
Old April 14th, 2009, 05:04 PM   #16
TN.Frank's Avatar
I planned on taking at least two days if not three to get everything done. First half of the first day, remove all the old stuff, second half, bolt up the new stuff, Second day, tune everything in and Thrid day just incase ol' Murphy strikes.
Old April 14th, 2009, 05:05 PM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Your headers are stock unequal length headers.
Old April 14th, 2009, 05:08 PM   #18
TN.Frank's Avatar
So is that a "YES" to working with the GT40p Explorer heads?
Old April 14th, 2009, 05:10 PM   #19
yes
PeteAndersonRacing.com
Old April 14th, 2009, 05:12 PM   #20
91Project's Avatar
1991 Mustang GT
If your going to spend the money making air flow better why would you want to stick with the factory headers?
Threads Similar to: '98 Explorer heads and intake.
ford explorer heads? rusty2407 5.0 Mustangs 30 December 15th, 2008 08:24 PM
I have-96 Explorer HEADS/INTAKE-?Anybody Interested? STREET6 5.0 Mustangs 5 May 10th, 2008 10:37 PM
Explorer heads, What years? roscoe 5.0 Mustangs 5 June 14th, 2007 06:44 PM
Explorer Heads? 95stallion 94-95 29 December 24th, 2006 01:21 AM
explorer heads and intake coreyfitz 5.0 Mustangs 14 November 26th, 2006 06:09 PM
