Electrical Problem
To start off, my friend and I looked at the Tmoss electrical diagrams and tested voltage and power for a few hours last night trying to solve this problem so I'm not blindly asking this question. My fuel pump doesn't turn on when I turn the key to run. Everything else seemingly works: wipers, windows, starter, we're getting spark, but the fuel pump doesn't turn on. We tried a pump that we know works, so we've eliminated the pump being the problem. At the pump we're only getting [U]8 volts[U]. I forgot if how much voltage the fuel pump relay is getting, but I know the relay is good because I switched that out with a known good one. Now I did accidently touch the starter wire directly to the power wires on the starter solenoid, which cause some big sparks, but it didn't blow the fusible link on the 18g orange/light blue fuel pump wire. I guess my question is, is this drop in voltage a bad ground? or is it possibly something computer related? (We did change the computer out with a known good one with the same result.) When I turn the key to run, I hear a pretty loud clicking right near the computer. Could the relay right above the computer be bad?
ecm is fubar replace i know from experience
Moderator
I thought the fuel pump relay was under the drivers seat
you can attribute that drop in voltage to be a bad ground. If you are sure that the relay and comp were good then it something in the wiring.
![]() ![]() BUILD 2 IN PROGRESS |
91' 5.0 LX
![]() iTrader: 1 reviews
If the wire is chafed somewhere along the line, it may be grounding out on the frame, causing the drop in voltage.
1990 LX hatch
Inertia switch
91' 5.0 LX
SVTfocus, F250
switch infront of the drivers tailight behind the plastic. it trips if there is a big g force hit to turn the fuel pump off, take the panel off and see if its tripped
Moderator
yes, try that as well.
Holy old thread. The problem ended up being that someone had cut a one of the wires to the relay to add in a fuel pump cutoff switch, but there was not switch there and the wires were hidden in the loom. I simply connected the two ends of the wire and it worked perfectly.
SVTfocus, F250
holy shit this is old 5.slow dug deep to find it haha
Threads Similar to: Electrical Problem
| electrical problem | sixpack | 5.0 Mustangs | 6 | April 27th, 2008 07:33 PM |
| Electrical Problem | Drtbkercr5 | 96-98 | 3 | April 11th, 2008 11:59 PM |
| Help...Electrical Problem | ZOOTOXIN | 99-04 | 20 | January 11th, 2008 04:12 PM |
| Electrical problem..... | Klawin | Audio/Video | 0 | September 18th, 2007 09:24 PM |
| electrical problem | Darren E | 5.0 Mustangs | 4 | April 18th, 2007 04:00 PM |
