Hurt The Mustang Last Night At The Track
Old April 16th, 2009, 10:47 AM   #1
White 89 is infamous around these parts
Made three passes on the mustang last night. On the last pass I get done and the fire crew stopped me and said you know you are leaking anti-freeze. I got down and looked and it was just gushing out.
Looks like the anti-freeze was leaking from between the water pump and the block. Like the gasket blew out or something
Now look at that pump. Notice something. Yeah a bolt missing. Not really sure if a bolt goes thru there or not or if it’s just a drilled and tapped hole or what. ON lunch break I’m going up to auto-zone up the road to take a look at one see if that very bottom hole is thru or not. That’s the only thing I can tell right now is that the bolt worked its self out and the gasket blew right there. But see it has threads. The holes on the pump should just be drilled holes not tapped. The tapped part would be in the block.
Water was coming from inbetween the pump and the block. I’m not sure where the small drain hole is when the bearing goes out. I think it’s on the shaft or hub area. I can’t remember. Water was leaking from in-between anyway. So……..
My question would be have you ever seen a gasket blow out. The gasket that is sandwiched between the pump and block.
1989 mustang GT 5.0
Old April 16th, 2009, 11:00 AM   #2
BORDEN's Avatar
91 lx convt
14.02@100
BORDEN is on a distinguished road
how long has the gasket been there. it looks like a fairly new waterpump
Old April 16th, 2009, 11:02 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Is it leaking from between the water pump and timing cover or is it coming from further back like between the timing cover and block? If its coming from further back it could be a cracked block. That is where they start to leak when they split.
Old April 16th, 2009, 11:24 AM   #4
From laying on the ground looking up under the car.
I saw water leaking behind the balancer. Not really 100% sure exactly where. My thoughts was in-between the pump and block. But could be further back.
Have any ideas how I can tell.
The motor was still running. Not like it shut off on me.
1989 mustang GT 5.0
Old April 16th, 2009, 11:25 AM   #5
I want to pour water in it and fire it up?
1989 mustang GT 5.0
Old April 16th, 2009, 11:35 AM   #6
hey if the block is cracked would that mean WATER in the oil?
should I pull the dip stick and have a look
1989 mustang GT 5.0
Old April 16th, 2009, 11:51 AM   #7
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
for sure check the oil better safe then sorry
Originally Posted by Dennis View Post
great thanks i think i just lost 50 points off of my IQ reading that
Old April 16th, 2009, 08:10 PM   #8
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
no..it goes water pump with a gasket to the timing cover,then timing cover with gasket to the block..
Cohagan Engineering, Inc.
Old April 16th, 2009, 08:55 PM   #9
Mlx50man's Avatar
90 Mustang lx Boss 347
Mlx50man is on a distinguished road
Send a message via AIM to Mlx50man Send a message via MSN to Mlx50man
if its threaded holes in the pump then a bolt doesnt go through there, that is for the plate that is on the back of the water pump.
Old April 16th, 2009, 11:31 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes, check the oil for antifreeze/water.
Old April 20th, 2009, 09:53 AM   #11
it was the water pump
1989 mustang GT 5.0
Old April 20th, 2009, 12:50 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is good news!
Old April 20th, 2009, 01:05 PM   #13
yeah it is in sort of a way.
I replaced it just over a year ago. like 14 months ago.
why'd it go out so soon.
1989 mustang GT 5.0
Old April 20th, 2009, 01:17 PM   #14
1992 Lx
11.39@119.24
warranty that bitch, what did you run at the track?
Old April 20th, 2009, 01:20 PM   #15
+ 99 What did she run....
PeteAndersonRacing.com
Threads Similar to: Hurt The Mustang Last Night At The Track
Video to last night's track night for WOT Mustang Club RStrick0352 2005 - 2010 0 September 20th, 2008 08:52 PM
First Night At Track 90Stang 2005 - 2010 12 May 26th, 2008 04:08 PM
Went to the track last night. 1slo5.0 The Clubhouse 11 September 8th, 2007 03:39 PM
My first night at the track!!! ddashtrois 99-04 28 June 3rd, 2007 05:55 PM
Went To The Track Last Night Drgnracin72 The Clubhouse 56 October 4th, 2006 07:53 AM
