Today is the day...! - Page 2
Old April 17th, 2009, 08:47 AM   #21
1986 Mustang GT
7.88 @ 176
flyin_hawaiin is on a distinguished road
oh, 2 other things LOL..
#1 the car's rear end was about to fall out and explode.. it was VERY VERY NOISY and i was afraid something was going to happen.. if i had to bet, there was something going on it there generating ALOT of heat.
#2 IN MY EXPERIENCE, bigger cubes dont make much more HP... what they do make is more TQ... most 302/306 tfs headed motors make similar HP and i agree.. but the tq is usually 20-25 up with the 331..
Old April 17th, 2009, 09:13 AM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by flyin_hawaiin View Post
hey guys..
first off, the dyno we use reads extremely conservative. My own race car makes 80rwhp less on our dyno then on speed inc's dyno. The owner of the shop recently bought speed inc's twin turbo shop car and we put it on the dyno after it was tuned at speed inc. At speed, his car made just shy of 1200rwhp. On our dyno, it made 1087rwhp... NOTHING CHANGED!! We attribute it to the Eddy current load cell that we have... I also tuned a renegade car from St. Louis who was owned by a shop owner down there. We made 808 rwhp and he went home and made 888 on his dyno..
Anyhow, i had to be conservative. Why you ask?? Well, there was NO TIMING POINTER ON THE CAR!!! I had to "guesstimate" on setting the timing to 10degrees... If this were a blown or turbocharged car, i would have passed on it.. I have done enough fox bodys to get a good idea on where the pointer is located, but i wanted to be safe. Scott was nervous from the get-go and i didnt want anything to happen. His first comment when he got there was "where can i go smoke" LOL..
Anyhow, before we made a pull, i told him that i was expecting 300-310rwhp and around 320+ tq... this is what these cars make ON OUR DYNO! Remember, this was an unported set of heads and a TFS intake..
anyhow, thanks
bob
I figured there was an explanation Bob. Nobody was doubting your ability so don't take it that way. The part about the timing pointer missing was left out of the original post . I also understand that some dynos are conservative and there are alot of variables with chassis dynos which is why I told him "I guess the numbers really don't matter, the track will tell you how it performs. If you are happy with it, that is all that matters".
Old April 17th, 2009, 09:13 AM   #23
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Yeah, the timing pointer was a huge mistake on my part. There's no doubting that, but in all honesty, the cars been sitting 2+yrs I'm happy the car is running! There are numerous things left for me to fix on the car, ie: Temp. gauge sensor needs to be moved, my tach is off, the rear-end, I need to add a fan to the radiator. So this car isn't done by a long shot... As for the "coin" dumped into this build in the past 3months, none of it has gone to waste IMO. Sure I could have done things differently, or choosed this part over that part, but IMO the engine bay looks awsome, car sounds good, and once I get these loose ends taken care of the car might have to go back to Bob. What can I do other than that. So again, thanks to Bob and well me I guess for putting it together lmao.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old April 17th, 2009, 09:18 AM   #24
e3sean's Avatar
1988 lx
9.68@142
good job man just keep building it and fixing the problems one at a time.
<font size=4><b>MILITARY CREW
Old April 17th, 2009, 09:37 AM   #25
1986 Mustang GT
7.88 @ 176
not offended at all, just stating my case... I was actually quite happy with how things went considering it started off on the wrong foot with no timing pointer.. Im sure this thing will be a joy to drive after all the little things get fixed..
thanks!
bob
Old April 17th, 2009, 09:55 AM   #26
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Don't sweat it dude. Everybody makes mistakes. I put a sawzall blade thru the side of a mint condition notchback ones...by mistake. You can put the timing pointer on anytime. You picked the right person to tune it so I'm sure the thing will run like an rabid animal. I'd for sure look into that rear end before you drive the car anywhere. Obviously there is a problem there.
Old April 17th, 2009, 10:14 AM   #27
1988 GT
Yeah, before I went to Bob I contacted Strange since their 20min. from my house. For them to weld the tubes to the case, new gear(4.10), 31-axels, c-clip removal, steel spool, and a two week turn-around is $1320. And +1 on the rabid animal, this thing sounds great and with the rear-end should run great as well.
Old April 17th, 2009, 11:18 AM   #28
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Lol. I wish I could of seen your facial expression on that one. Great numbers, just wait for the track numbers. People just don't understand conservative dynos. I did 350 on a mustang dyno. 10 degrees base timing, and tons of belt slip, and the car only makes 7 pounds in 4ths gear. But with a tight belt it runs nast. Tie up the odds and ends and enjoy it.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old April 17th, 2009, 12:40 PM   #29
91 LX
13.7@101
your going to run a spool?
Old April 17th, 2009, 12:54 PM   #30
1988 GT
Yeah, with 31-spline axels. It's not my DD, and I've made plenty of sacrifices already I don't see why a spools' driveability should stop me now. Besides, it sounds bad-ass when you say, "Yeah it's got a spool in it"
Old April 19th, 2009, 11:47 AM   #31
1986 Mustang GT
7.88 @ 176
Hey Scott.
thanks for coming out yesterday and supporting the True Street race!! We will be racing again on May 9th if you want to come out again.. hope to see ya!
thanks bob
Old April 19th, 2009, 12:04 PM   #32
1fasts/c2003's Avatar
1fasts/c2003 is on a distinguished road
you should be around 350 to 360 hp with that set-up, sounds good man, i just finish the install of bbk lt with bbk h-pipes and i love the way the car sounds and it appears to pick up a little more power, i see you have a similar set-up as the one i have. did you go with lt or shorties? i will post a video with the new headers. congrats on the car.
1996 gt ported prototype stage 1 npi heads,stage 2 bullet racing cams, bbk lts, bbk x-pipe, magnaflow catback,professional product throttle body, cai, aluminum driveshaft, 3.90 gears, upper and lower control arms.
v-3 vortech s/c 416rwhp/426rwtq
Old April 19th, 2009, 12:19 PM   #33
Mustangshar's Avatar
2006 Mustang GT Vert
Mustangshar is just really niceMustangshar is just really niceMustangshar is just really niceMustangshar is just really niceMustangshar is just really nice
Congrats...that's fantastic. Bob is the best in the business out in the Chicago area, good choice there!
Sharon
Don't go there.......
06 GT: MM & FF 12/07 Ladies Edition issue: will never be done
Old April 19th, 2009, 02:26 PM   #34
91 LX
13.7@101
what does a spool do for you tho? why not buy the eaton limited slip for 31 spline axles. that is a great piece
Old April 19th, 2009, 08:10 PM   #35
baine21225's Avatar
happy you got it running right, good luck with it
Old April 19th, 2009, 08:55 PM   #36
Well said
PeteAndersonRacing.com
Old April 21st, 2009, 05:09 PM   #37
1988 GT
Hey Scott.
thanks bob
It was a blast, I had so much fun. Except for the hang-over it was a great time. It was nice to see your car in person, and I'll absolutely be there on the 9th.
The spool is like a locker all the time, I've heard if you're ever "on and off" the throttle in a limited-slip sometimes it wont engage, or "slip".
Threads Similar to: Today is the day...!
So Today is my b day Haseeb718 The Clubhouse 18 December 13th, 2008 05:48 PM
Today is my b-day El_Cangri The Clubhouse 12 February 24th, 2008 09:17 PM
Today is the day... homebrewed The Clubhouse 20 October 23rd, 2007 12:40 PM
Today is not my day! dmachine22 99-04 0 March 25th, 2007 07:06 PM
