performance cam/stock heads?
i have a cam with the same specs as a fms e303...can irun it with stock heads or is that completely pointless.
sorry this is probably a repeated question/topic
get sydewayz |
all motor
92 coupe
9.94@136.40
Do you have the pushrods for the cam? or springs/retainers? If yes, then install those as well, and you're good to go
i dont no. im new to this...r there specific pushrods/springs/retainers for the cam lift?
get sydewayz |
The e303 is a bit much for the stock heads....
all motor
92 coupe
9.94@136.40
Yeah, you need specific pushrod lengths,spring ratings and probably retainers, and maybe rocker setups as well. That is supposed to be a good cam from what Ive heard. I would also at least port/polish the stock heads, or think about upgrading.
no...what im saying is, thats a bad cam to use on the stock heads. there's not enough airflow for the lift. If your going to use that cam, either get some better heads, or have your heads ported..
#7 | |
basically hes right u could use it on the stock heads and u would see a gain but not much, now if u port the heads u would see a pretty decent gain, but yea aftermarket is the way to go
You might see a bit more power with that cam but I think the major thing you will notice is throttle response. It should be a noticeable improvement but don't expect big horsepower numbers. Make sure you change your valve springs.
if i went with gt40p heads would that b enough and what kind of headers would i be able to run with them...and any other suggestions for aftermarket heads for say..under 600....700....??
get sydewayz |
u could find some used heads afr's for like 700 or some edelbrock for pretty cheap.
and yea gt40p's would be a good head to go wit. then have them ported out and they flow better than the afrs so gt40p is good its what im doin and the cam im using is huge |
#11 | |
Ported GT40Ps won't flow anywhere near an AFR head.
#12 | ||
x3
i'd go with the afr 185 heads.. when u do get some heads
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
#15 | |
#16 | |
Moderator
There's a reason Ford codenamed them the Terminator
#17 | ||
The afr165s flow a good 55cfm over the gt40p heads on the intake side @ .500" lift if im correct. Gt40p heads wont touch an AFR165 head, and they cant even see 185s. Somebody told him a HUGE lie when they said gt40p heads flow better than AFRs. Go to any real shop that does real work on mustangs and tell that bullsh*t to someone there and see if they dont laugh in your face. No disrespect, but you have no idea what you're talkin about. If you're using a huge cam with gt40p heads, you're choking the hell outta your engine. Either that, or you dont know the definition of huge. |
98 Explorer GT-40 heads, bone stock, replaced the springs to some trickflow springs that summit recommended. Installed Stage II Trickflow Cam, had timing adjustments made by a friend of mine... No choking, spits, misses, pops and pings nor power lag. With the current setup I make slightly 300hp. I still have some work to do on the darn car.
Now don't get me wrong, I listen to these guys when I run across posts from them like darrell. So what they are saying is something you will never hear from those unexperienced dummies at the Ford shop, but at the same time others will say you can make more horsepower out of stickers and fart pipes but these guys will tell you what needs to be done. Hell, thanks to some of these guys, I got the right parts the first time and got my 3.73 gears.
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
Threads Similar to: performance cam/stock heads?
| Patriot performance stg II heads with cams | Monster stang 97 | 96-98 | 15 | April 26th, 2007 07:18 PM |
| Patriot Performance Heads | CantDrv55 | 99-04 | 2 | March 17th, 2007 11:51 PM |
| Hollowed out stock h pipe performance? | Jeff99gt | 99-04 | 2 | February 2nd, 2007 09:07 PM |
| Hawk Performance Heads | militarygt | 5.0 Mustangs | 5 | October 6th, 2006 05:17 PM |
