Used AFM PMS tuning issues
Old April 17th, 2009, 12:14 AM   #1
FivePointSlow777's Avatar
1993 Mustang GT
FivePointSlow777 is on a distinguished road
Send a message via Yahoo to FivePointSlow777
Hi, i bought a used PMS 3 and installed it the other day and after about an hour i got the car able to run and go down the road but it still is not running right at all, it seems like any adjustment that i make arent really being applied, ive read the manual but either i didnt get it or it just told me what it was not how to tune it effectively, i really want to learn, any help would be greatly appreciated
Old April 17th, 2009, 12:57 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you don't have any tuning experience its going to be very hard to tune without having it on a dyno and also having a wideband O2. There is a reason why people put their cars on dynos to tune them.
Old April 17th, 2009, 02:48 AM   #3
The pms has three memory slots meaning it can remember three different tunes.. after you make changes you need to save it before turning the car off because if you don't it defaults back to the tune loaded before you messed with it. If you saved it before turning the key off then your new tune will always be loaded as default until you make more changes and save etc.
You can give Anderson Ford a call and tell them what you have.. they can hook you up with a base tune to work from for like $50 I believe at least that's waht it use to cost.
From there you can make small suddle changes as you go and watch your AF. also if you don't have a wideband hooked up then you really are shooting in the dark, take the car to a good tuner with a dyno. He'll throw it up on the dyno and make the changes and since you have a pms already there's no need for burning a tune and purchasing a chip or flip chip so a tune should only run you $200 to 300 bucks ddepending on the tuner and area where as without the pms it would be in the $500 to 700 range.. at least it is around my area
Threads Similar to: Used AFM PMS tuning issues
408 stroker tuning issues Genevieve! All Other Vehicles 16 January 13th, 2009 04:26 AM
holley 600 cfm tuning/issues viperlocc 5.0 Mustangs 3 October 14th, 2008 11:04 PM
Tuning issues genericcobra 4V / SVT 13 September 20th, 2008 09:53 PM
First time at the track after tuning issues....... 86GT50 5.0 Mustangs 13 August 9th, 2007 12:56 PM
Tuning Issues 5.0 w/trick flow heads 1slowhatch 5.0 Mustangs 2 April 23rd, 2007 12:56 PM
