oil pressure gauge
Old April 17th, 2009, 12:52 PM   #1
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
oil pressure gauge
OK guys, i bought this gauge a while ago and its just sitting here on my desk basically because i have never installed one and dont know how to. so how do i do this? does it take an after market sending unit? do i need anything else along with the gauge and a length of hose or tubing for the oil?
Old April 17th, 2009, 01:51 PM   #2
91 LX
13.7@101
you need a sending unit that threads into the stock gauge's sending unit location which is next to your oil filter. also you need wiring
Old April 17th, 2009, 02:16 PM   #3
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
mechanical or electric???
mechanical, you unscrew the factory sending unit by the oil filter and thread the fitting in its place that's at the end of the tube... then you screw the other end of the tubing onto the gauge...
Old April 17th, 2009, 03:36 PM   #4
1988 Mustang
ok, yeah its mechanical, the gauge i got came with a tube i believe its a 1/8" i can really make out exactly what it says but pretty sure its 1/8". so basically i need a fitting to accept the 1/8" to connect my tube to?
Old April 17th, 2009, 08:38 PM   #5
11.8@113...150 shot
yes, i believe you can find what you need at ace hardware...
it will be a nut and a small cone piece...
i think its called a pressure fitting...
Old April 17th, 2009, 08:54 PM   #6
1988 Mustang
aight thanks.
Old April 17th, 2009, 11:06 PM   #7
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
Make sure to install it with copper tubing and not the plastic poly flow that comes with them.
Old April 18th, 2009, 01:37 AM   #8
1985 Mustang GT
viperlocc is on a distinguished road
ive never had any problems with the nylon hose. i only ran copper if i have worries that it'll touch the exhaust mani.
Old April 18th, 2009, 08:39 AM   #9
1988 Notchback
11.19 @ 122mph N/A
keep using the poly flow and you will have problems out of it.
Old April 18th, 2009, 01:09 PM   #10
1985 Mustang GT
like what? the gauge was installed with the previous owner in '99 and has never changed the hose
Old April 18th, 2009, 01:11 PM   #11
1988 Notchback
11.19 @ 122mph N/A
They will blow out, I have seem them do it several times. If it is working for you and you feel comfortable about it then just leave it be, it's your car so do what you wish my friend.
Old April 18th, 2009, 04:02 PM   #12
TN.Frank's Avatar
1989 Mustang GT 5.0L H.O.
TN.Frank is on a distinguished road
I went to pull the mechanical OP gauge out of my car this a.m. and install a sending unit to see if the stock in-dash gauge would work(it did by the way, the guy was just to lazy to fix the problem right and rigged it with a mechanical gauge.) and the nylon tube broke in half, that stuf isn't the best, I'd much rather use copper provided you can be careful with it and not crimp it or otherwise weaken it. Even better yet, get an electrical aftermarket gauge if you don't like the factory one. That way you've not got hot, high pressure oil in the car with you.
Threads Similar to: oil pressure gauge
Oil pressure gauge RC02GT 99-04 17 March 22nd, 2009 01:09 AM
Oil Pressure gauge Novanutcase 99-04 11 January 21st, 2009 10:54 PM
oil pressure gauge HMUSN 5.0 Mustangs 6 May 14th, 2008 08:34 PM
oil pressure gauge ThE GhOsT RiDer 5.0 Mustangs 1 April 24th, 2008 03:52 PM
Oil Pressure Gauge Question Pastor J 2005 - 2010 6 September 6th, 2007 01:25 AM
