Tried and true way to get 300-320 rwhp?
Old April 17th, 2009, 08:02 PM   #1
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
I have been searching around and have seen quite a few different setups that would be good for what I want. I have been tossing around quite a few different idea. I just want some of your opinions and setups.
What I want:
300-320 whp
N/A no boost or spray.
Affordable, I'm not made of money but I'm not on a super strict budget either.
Old April 17th, 2009, 09:10 PM   #2
So you just wanna race the dyno not the track?
PeteAndersonRacing.com
Old April 17th, 2009, 09:29 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There are many ways to get that much horsepower. I guess you need to define what affordable is first.
Old April 17th, 2009, 09:33 PM   #4
Newblet
87FloridaGT's Avatar
1987 GT
87FloridaGT is a jewel in the rough87FloridaGT is a jewel in the rough87FloridaGT is a jewel in the rough
^^ Who does your hair?
Old April 17th, 2009, 10:00 PM   #5
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
What I want:
300-320 whp
To get that kind of hp to the wheels N/A, the easiest way would be an expensive H/C/I swap or build a 331 or 347 stroker
Old April 17th, 2009, 11:14 PM   #6
BoostFiend's Avatar
11.63@120.08, Cobra
Haha, I know this is just a typical Mustank comment so I will refrain from being a dick in return.
No, actually I would like the car to run well at the track but I will be using the dyno as a tuning tool. I don't really care if I have 12 hp or 500 as long as I have a good running setup that gets results.
Thanks for your input.
Old April 17th, 2009, 11:24 PM   #7
BoostFiend's Avatar
11.63@120.08, Cobra
Yeah I have actually looked into all 3 options. My stock block has 77k miles on it and hasn't been romped on. As far as long term which is the better option?
What setup are you running to get the times in under your avatar? NVM, just checked your garage. Nice car.
Old April 18th, 2009, 01:25 AM   #8
well the tfs top end kit is a proven 300 to the wheels out of box so couple that with porting etc but you should really put dollar figure down to how much your limit is. I think that would help gauge what parts can be used and what can't be.
Old April 18th, 2009, 01:35 AM   #9
BoostFiend's Avatar
11.63@120.08, Cobra
I'd say around 2k give or take, just depends on if I sell another one of my cars then that figure might go up substantially.
Old April 18th, 2009, 02:33 AM   #10
86er's Avatar
2k start hunting the used parts section.
that barely gets you heads and intake new.
closer to 3k after all the misc stuff you will need.
Just a truck
Old April 18th, 2009, 02:43 AM   #11
Then why not go with a nice set of heads and some juice
Old April 18th, 2009, 02:57 AM   #12
BoostFiend's Avatar
11.63@120.08, Cobra
I'm not opposed to going with used parts. I also already have some odds and ends as far as parts. I can actually get a '97 exploder upper and lower for dirt cheap, so if I went with that, bought a nice set of heads, a good cam, and then a nitrous kit what do you think of that?
Old April 18th, 2009, 03:02 AM   #13
86er's Avatar
I thought you didnt want nitrous? you put heads/cam and nitrous you will leap frog your 320 goal with ease and approach the 400+ range
Just a truck
Old April 18th, 2009, 03:07 AM   #14
BoostFiend's Avatar
11.63@120.08, Cobra
I would rather go with N/A but was kinda thinking about what flyin ryan said. I could probably pick up a Zex wet kit for pretty cheap from a buddy.
Could I break 300 with the Exploder intake, good heads, and a custom grind cam? If so I wouldn't need the shot.
Old April 18th, 2009, 07:27 AM   #15
1988 Notchback
11.19 @ 122mph N/A
^^^^ Along with supporting mods to go with H/C/I, then yes, you will break the 300rwhp mark. AFR 185 with custom cam will put you where you want to be.
Old April 18th, 2009, 08:41 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'd use the stock short block. 77K isn't bad and if it runs good now it will be fine with some upgrades.
2K might be tough. You will need:
- heads
- head bolts
- cam
- intake
- rocker arms
- valve springs
- gaskets
- misc. parts
Start looking for some Canfield or Trick Flow Twisted Wedge heads used. You should be able to find them all over. Even AFR165s will work if you can't find anything else. A cam like Comp Cams XE276HR will work other wise if you have the extra cash I'd have Camshaft Innovations grind one for you. Pass on the Explorer intake. I would look for a Systemax or maybe a TFS Track Heat or R-series intake. All of these parts will put you in the horsepower range you are looking at and on a slick will run high 11s in the 1/4 if you can drive.
Old April 18th, 2009, 08:42 AM   #17
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
AFR185s won't work with stock pistons without cutting bigger valve reliefs.
Old April 18th, 2009, 10:31 AM   #18
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
isn't it a lot to ask of stock injectors to make 300 at the wheels ??
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old April 18th, 2009, 10:36 AM   #19
86er's Avatar
N/A nope
Just a truck
Old April 18th, 2009, 10:41 AM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Probably since realistically they only support about 300 or so flywheel horsepower.... I'd get a set of 24lb or 30lb injectors if it was my project.
Threads Similar to: Tried and true way to get 300-320 rwhp?
how to achive above 300 RWHP Bkbulldog 2005 - 2010 49 September 28th, 2008 05:11 PM
Cheapest way to 300 rwhp? vomitron 2005 - 2010 54 August 30th, 2008 08:32 PM
i think ill be round 300 rwhp bricky77 99-04 52 September 8th, 2007 01:13 PM
