Piston Question with pictures ???????
Old April 18th, 2009, 02:46 AM   #1
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
The other day I was cleaning up my pistons to put on the new rings and rebuild the short block. I was using gas but it was a real slow process. I had some of that ZEP purple cleaner sitting on the shelve so I put some in a bucket and added some water. That Purple cleaner works awesome on grease if you have ever used it before, well needless to say when I pulled out the pistons they were spotless!!!
They were so spotless that it started to take off the silver coating on the skirt of the pistons! These are stock Ford forged pistons from a 1989 5.0. I never knew if or that they ever put a coating on stock pistons but some small thin film of a metallic something was coming off.
The pistons only sat in the cleaner for an hour.
My question is; what is the coating that was coming off? Is it a thin outer layer of the piston it's self? Do you thing these pistons are useable anymore or did the cleaner ruin the aluminum?
I called DSS and asked them but didnt get any answer. I'm looking to you for advise or if anyone has done this and had this issue before.
Old April 18th, 2009, 02:47 AM   #2
1990 LX Coupe
Old April 18th, 2009, 02:49 AM   #3
1990 LX Coupe
Old April 18th, 2009, 06:20 AM   #4
Quick99's Avatar
1999 Mustang GT
Quick99 is on a distinguished road
May as well keep soaking them and see if the rest of that crap comes off.
Old April 18th, 2009, 07:19 AM   #5
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
I wouldn't use them if it were me. But I'm not sure of what kind of budget you are on. Best thing to do is have them bead blasted now that this coating has started to come off. Can you imagine what these pistons would do now if you were to reinstall them and run them. I foresee alot more of this stuff coming off and getting in between the bearings and crank/camshaft and causing severe issue's. If you can't have them bead blasted, do yourself a favor and toss them out and get a new set. I also see some marks on them that I don't care to see. Besides, stock pistons are an old TRW slug that is a little on the heavy side. get an aftermarket piston with nice valve reliefs so you can upgrade to an alot better camshaft.
Old April 18th, 2009, 08:47 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If it was me, I wouldn't use them......I wouldn't have used "puple people eater" cleaner either.
Old April 18th, 2009, 10:53 AM   #7
e3sean's Avatar
1988 lx
9.68@142
ya the purple stuff eats metal real bad.
the best way to clean a piston i have found if you cant hot tank them is carb cleaner and steel woll
dont reuse those pistons... hell its apart might as well bump the compression up a lil anyway or lower it for boost or stroke it... the possibilitys are endless!!
<font size=4><b>MILITARY CREW
Old April 20th, 2009, 12:48 AM   #8
1990 LX Coupe
thank you for the comments. I took them to the track Saturday night for the race and asked my buddu's engine builder what he thought. He said basically the same as you guys, Why would I soak them in that crap and he would not use them.
He said they could be cleaned up and used by why would I in the engine that I'm building. Because of the supercharger, he said get new ones, dont take a chance..
Anyone wanna buy a cheap set of clean factory forged pistons.... Cheap!
Old April 20th, 2009, 01:13 AM   #9
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
$5 + shipping
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old April 20th, 2009, 01:35 AM   #10
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
how much u gonna pay me to take them????
Cohagan Engineering, Inc.
Threads Similar to: Piston Question with pictures ???????
Piston problem JBIGBOOTSY 5.0 Mustangs 9 April 27th, 2008 01:54 PM
Piston Clearance 95StangMX 5.0 Mustangs 11 January 10th, 2008 10:51 AM
Piston Question bigbadtalontsi 5.0 Mustangs 5 January 18th, 2007 11:20 AM
PISTON ? 89GTCONV 5.0 Mustangs 1 June 14th, 2006 09:44 PM
new motor prep nitrous/piston question 173speed 5.0 Mustangs 11 October 12th, 2005 11:37 PM
