What is the diffence between a 86 a arm and a 87 up a arm?
Old April 20th, 2009, 09:30 AM   #1
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
Anyone no what the difference is? I have a 86 but have 95 spindles and ball joints for the 5 lug conversion.I think the difference is in 87 they changed the geometry for better ride this is why i am looking at using them i want to go with tubular and some new lowering springs.
Old April 20th, 2009, 01:41 PM   #2
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
good question, i hope someone answers it bc i would like to know also.
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old April 20th, 2009, 03:00 PM   #3
hopper is on a distinguished road
to be honest i had no idea there was any difference.
Old April 22nd, 2009, 01:08 AM   #4
86ttops's Avatar
n/a
I was looking at buying a tubular set and it lists two diffrent ones.
Old April 22nd, 2009, 07:54 AM   #5
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
I think one is longer than the other cause I have one of each on my car so I have one with a spring isolater and one without so that my car will sit level, I didnt know there was a differnce when I replaced mine
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old April 22nd, 2009, 03:16 PM   #6
86er's Avatar
susp for the front on everything ive seen is 79-93 and then 94 and up
Just a truck
Old April 22nd, 2009, 03:32 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
I do think the balljoints are different on the 86 and earlier Mustangs due to a difference in spindles. 86 and earlier had wimply little brakes and such in the front but I don't think length or geometry of the control arm is different.
Old April 22nd, 2009, 05:45 PM   #8
86er's Avatar
hell you can bolt up the 94 and ups, just gotta use the 94 and up spindle, believe it sticks out just a smidge or stands a smidge taller
Just a truck
Old April 22nd, 2009, 07:22 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'd like to see that done. How would you correct the steering geometry? The SN95 control arms are about an inch and a half longer than the fox body arms. I just went thru this on a 95 Cobra not too long ago. Fox body control arms suck the tires in so far that it looks like shit and there is no way to adjust it so the tire sits flat.....short of moving the strut towers in further. I can only see this problem being the opposit on a fox body with an SN95 control arm. The spindle has nothing to do with it, its the control arm length that is going to cause the problem.
Old April 22nd, 2009, 08:49 PM   #10
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Darrell~ not sure if this would help, but maybe finding a different offset wheel would do the trick?
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old April 22nd, 2009, 10:50 PM   #11
89LX347's Avatar
89LX347 will become famous soon enough
i think you would get into either putting the wheel and tire so far in that it rubs or sticking it out so far the it looks messican. and it still wouldnt make up for it being improper.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 22nd, 2009, 11:18 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The different offset won't make a difference. The camber is still going to be so far off that the best caster/camber plates on the market won't have enough adjustment to correct it. The difference in length on the control arm moves the bottom of the tire in or out, the top (strut mount) stays in the same spot.
Old April 22nd, 2009, 11:23 PM   #13
86er's Avatar
I never said it would work,just said they would bolt up lol =)
Just a truck
Threads Similar to: What is the diffence between a 86 a arm and a 87 up a arm?
control arm bolts hardhitter 99-04 10 January 6th, 2009 08:55 PM
a arm install question.... blackhavok 2005 - 2010 1 September 28th, 2008 11:14 PM
AZ needs to arm the borders!!! 93HatchsBFF The Clubhouse 2 July 19th, 2008 12:03 AM
any help with a hurting arm???? 97Cobra The Clubhouse 23 June 12th, 2008 04:50 PM
Roush Shifter Arm 94gt 94-95 0 April 4th, 2008 07:53 AM
