Would i feel advancing the timing/ is it worth it?
I'm running 10 degrees right now and using 87octane. I was wondering if i go to 14 advance or so and run 93octane would i feel it enough to worth the the more money at the pump?
definetly advance the timing, 87 Octane is fine if you keep it under 14' and under. if you start to hear a "ping" you know it is pre-igniting, either retard the timing or run higher octane, definetly more power though
+1. IMO, i would go like 14 and just run 87. what motor you have? if you have the stock 302 or H.O. your comression should be at 9 to 1. if you have the gt40 setup you should be running at 8.8 to 1 then i would just go like 12 advanced, just my opinion.
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD. Plans: full black interior, black paint and supercharger??? |
1988 Notchback
11.19 @ 122mph N/A
It is worth more power, but usually not more than 10hp on an un-modded engine. The more the engine is modded, the more it will react to the timing advancement. Don't feel bad, my timing is set at 9* initial and 32* total.
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
i have my timing set back to stock now, 10*, i actually need to advance it again, but when i had my timing set to 14* i could tell a huge difference with it.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
it's worth it even on a stock car as long as you run the right octane and don't cheap out because it could cost you an engine
OK will do it 2moro cuz today it was to wet outside.
Its not stock only bolt ons though. aluminum underdrive pulleys, elec. fan, cobra gt40 ported intake manifold, bbk cold air intake, 24lbs injectors, pro-m calibrated 73mm maf, bbk shortys, o/r x-pipe, flowmasters, 3.73 gears, and E303 cam. All emission stuff and A/C deleted. |
ok i have hurd this before, but never understood it fully. the 9* is what you set the harmonic balancer to right? and where does the 32* come from? vacuum advance (or something like that)? how do you adjust that?
#10 | |
1990 Mustang GT
13.64 @ 101 MPH
i set mine at 16* on 93 octane with no knock but every engine is different
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
Threads Similar to: Would i feel advancing the timing/ is it worth it?
| stupid question, electronic cam advancing? | energiesource | 99-04 | 3 | June 23rd, 2008 01:16 PM |
| Advancing timing=how much power? | 8A_Honda | 5.0 Mustangs | 29 | September 9th, 2007 01:10 AM |
| advancing your timing | yellowstang98 | 96-98 | 1 | February 25th, 2007 04:56 PM |
