low vacuum?!
hey guys im trying to figure out wth is going on with my car it has 10 pounds of vacuum and compression on the 8th cylinder was dead and i brought it back up to 110. PISTONS AND RINGS ARE GOOD, THIS IS WHAT THE MECHANIC TELLS ME. car is not running how it should.. it has a miss at 1500 rpm 2500 rpm. ive posted a topic about this not too long ago and i havent gotten answers.. this all started happening when i changed the fuel pump which was a walbro 255 i beleive it was outside for sometime, im not sure if the fuel injector are dirty or clogged but ive checked the fuel pressure and its good its around 45. the only this is that pressure drops when the car is hot but not while im driving. when im at a stop.. the car has been in the shop for about a month and they cant figure out wtf!! is wrong with the car and its already gettign frustation.. sorry for the (wtf) PLEASE ANY ANSWERS WOULD HELP
1992 Lx
11.39@119.24
change your plugs
i dont know about you but ive had hands on expierence with buying a used fuel pump and the results were irratating. have you checked the injector pulse on that cylinder?
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD. Plans: full black interior, black paint and supercharger??? |
plugs may be the problem but i dont know how that would go hand in hand with fuel pressure dropping when it gets hot.
change fuel filter and fuel pump
#6 | |
Oh, and find a different shop because the one you are dealing with is obviously filled with idiots. These places get paid to fix vehicles, if they can't properly diagnose and fix a problem then they shouldn't be in business. Especially on something as simple as a fox body Mustang.
+1 right on man
well the dead cylinder was at 45.. the heads had some bent valves, but the problem is still there.. compression is at 110 or more not sure of the correct reading.. mechanic saids its electrical and i would take it somewhere else but i have credit with them so im not paying for anything.. either way they have to fix it. and the fuel pump has been out of the tank, i cleaned out the tank and put back the old one.. the guys saids its not the piston or the rings.. any suggestions?
get your car out of that shop. you can do what they have done for you... nothing. find a better shop
#10 | |
1990 Mustang GT
13.64 @ 101 MPH
find out what bent the valves. they just dont bend for no reason. but if they are bent yes compression will be low. check the pcm also for the fuel problem. i know theres been a few times ive seen a computer go bad and the car do the exact same thing
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
#11 | |
#12 | |
ok this guy is telling its an electrical problem because my valves are good piston and rings are good.. he changed the coil whic h was going bad, fixed all of my exhaust leaks..the only things is taht my vacuum is at 10, but i do have a mild cam, not sure which one i have...anyways he told me he pulled out the valve cover and did an air test to see if the air escapes from somewhere but it doesnt..he changed the valves and springs that were bad.. the guy is good from what ppl tell me because hes done a couple of my friends stangs that were worst than mine.. and hes taken care of them. i think its the fuel injector.. because the problem started happenning the day i changed my fuel pump but i put back the old one.. |
Threads Similar to: low vacuum?!
| Vacuum Qs | hmargov1 | Classic Mustangs | 3 | February 14th, 2009 06:05 PM |
| what low fat/low carb foods give energy | vfast | The Clubhouse | 23 | November 18th, 2008 08:25 PM |
| Low Profile Tire Series, How Low Is Too Low? | Steam | V6 Mustangs | 11 | November 11th, 2007 12:48 AM |
| Low compression and low Octane? | brad65 | 5.0 Mustangs | 5 | July 28th, 2006 04:53 PM |
