simple 3g wiring question
Old April 20th, 2009, 01:49 PM   #1
1998 Cobra
13.24@105.66
Wanting to do a 3g swap here soon..
On the 3 g, it has a 3 wire plug, stator plug, power wire and ground.
Ground is ground
Power wire is a 4g to solenoid
Stator wire runs to middle wire on plug
Left (yellow) wire runs to 12v
Green goes to dummy light...
But that's where I get confused. Can the green just use any 12v wire, or where do I need to run that to? My factory charging harness is garbage, so any help would be very useful.
All I have left to get my car on the road is the charging system and clutch... please help!
weeee foooord!
Old April 21st, 2009, 02:26 PM   #2
1998 Cobra
13.24@105.66
bueller?
weeee foooord!
Old April 21st, 2009, 06:58 PM   #3
89LX347's Avatar
89LX347 will become famous soon enough
if you are talking about a key switched item, then find a fuse that has power when the key is on and strip your wire, put it in the fuse hole and put the fuse back in.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 21st, 2009, 08:55 PM   #4
1998 Cobra
13.24@105.66
right right, but i've read on some write ups about a 500ohm resistor running in parallel with the warning light?
im lost lol
weeee foooord!
Old April 22nd, 2009, 06:07 PM   #5
ryans88gt's Avatar
It has to go to the green wire or your voltage regulator will not work due to the resistor thing in the gauge lite.
Basically the wight wire goes right back to the alternator stator and the thick wires go to the back. Green needs to hook up to the green wire in your alternator wiring. and yellow can just go back to the alternator + post, but you should put a fusible link in. Also make sure you use a fusible link or mega fuse in the 4 ga charging wire. If you ever blow a alt diode pack the fuse will blow before your car starts on fire, which is good.
Old April 22nd, 2009, 07:28 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Ground is ground
I'm confused, where is this green wire coming from? The D shaped connector is the same as the fox body connector so you can use the one on the car without modifying it or the wires. The rectangle connector is the only one you need to modify.
Old April 22nd, 2009, 08:11 PM   #7
1989 LX coupe 5.0L
89lx is on a distinguished road
darrell you wouldnt have a wire diagram for the 3g alt would you?
Old April 22nd, 2009, 09:13 PM   #8
1990 5.0 LX Notch
flamed 98 gt is on a distinguished road
I just did this yesterday and it only took about 20 minutes. I ordered this from PA Performance. No need to use the factory wiring harness.
PA-Performance is dedicated to offering high quality products to every consumer utilizing the Internet. - PA Performance - You Only Buy Quality Once ! 1.877.471.8010
Old April 22nd, 2009, 09:28 PM   #9
baine21225's Avatar
well that looks fancy dancy
Old April 22nd, 2009, 09:40 PM   #10
1990 5.0 LX Notch
It was very easy to install.
Old April 22nd, 2009, 11:24 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I don't have a wiring diagram but I can explain how to wire it if that helps? Its real easy.
Old April 22nd, 2009, 11:26 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Have you run it much since the install? How do you like it? I've had a few self exciting (one wire) alternators and hated them. My experience has been at idle they charge very little if at all. Hopefully what you have is better than the Chevy style alternators that I've used.
Old April 22nd, 2009, 11:31 PM   #13
baine21225's Avatar
so you like adapters like this?
Old April 22nd, 2009, 11:53 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yeah, if you have a 2 wire regulator but as far as I know all 87-93 Mustangs are 3 wire. No adapter harness is needed for a 3G on an 87-93 Mustang.
Old April 22nd, 2009, 11:57 PM   #15
ryans88gt's Avatar
Will not work correctly without the green wire and 500 ohm resistor unless it is built to work without it (i.e. self exciting one wire deal).
Old April 23rd, 2009, 12:07 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
All of that is already in place on 87-93 Mustangs so I'm still confused. I'm wondering if he cut the original plug off and threw it away.
Superbean, what year is your car? And please help with my confusion...
Old April 23rd, 2009, 12:27 AM   #17
1998 Cobra
13.24@105.66
The car is a 1988 2.3 lx..
Stock harness fits the alternator fine, just a bit tight, but it should work. It's not working though, so I just wanted to bypass all the factory wiring as I've rewired everything else from scratch.
Ignition, Fuel pump, fans, Push start are all controlled by made from scratch relays, so why not an independent alternator. lol
weeee foooord!
Old April 23rd, 2009, 12:47 AM   #18
1998 Cobra
13.24@105.66
well i went ahead and ordered a 3g alternator setup with a one wire regulator.
Since pa perf and late model resto make replacement 1 wire volt regualtors, i'll just go that route.
weeee foooord!
Old April 23rd, 2009, 12:54 AM   #19
ryans88gt's Avatar
yeah, the only wire you have to modify is the white wire to go to the stator plug and the thick wires to the back of the alt.
But if that isn't working, maybe the problem is in one of the fusible links.
The one wire set-up will work. Make sure you use a megafuse or fusible link on that one wire.
Old April 23rd, 2009, 01:29 AM   #20
1998 Cobra
13.24@105.66
Alright, thanks for your help everyone!
Alternator should be here by the weekend so I'll let you guys know how it goes
weeee foooord!
Threads Similar to: simple 3g wiring question
Simple Question GT33 2005 - 2010 11 November 28th, 2008 12:23 AM
simple LM question roxas331 2005 - 2010 6 November 19th, 2008 11:35 PM
A Simple Question: WAR-PARTY The Clubhouse 16 June 30th, 2007 01:48 PM
Simple question 8A_Honda 5.0 Mustangs 2 June 17th, 2007 10:12 AM
Simple question... 2000Mustang V6 Mustangs 37 April 13th, 2007 09:08 PM
